node-red-contrib-fff-ws-session-manager 0.0.3
A Node-RED node to manage WebSocket sessions
npm install node-red-contrib-fff-ws-session-manager
npm version License: MIT
A Node-RED node that tracks active WebSocket sessions and stores per-session configuration in Node-RED context. It reacts to connect, disconnect and update events, optionally encrypts the stored configuration at rest, and exposes a read API for downstream nodes.
Requirements
  • Node.js >=20.0.0
  • Node-RED >=4.0.0
From the Node-RED user directory (typically ~/.node-red):
The node is registered under the Feeding Systems palette as fff-ws-session.
Field Type Default Description
name string (empty) Optional editor label.
contextKey string ws_sessions Key under which sessions are stored in the chosen context scope.
scope enum global Context scope: global, flow, or node.
prefix string (empty) Optional prefix prepended to contextKey to isolate multiple instances.
encryptConfig boolean false When enabled, session config values are encrypted at rest (AES-256-CBC).
encryptionKey credential (password) (empty) Encryption key, stored via Node-RED credentials. Visible in the editor only when encryptConfig is checked.
preserveSessions boolean true When true, the persisted session list is kept across Node-RED restarts. When false, the list is cleared on every node initialisation.
Message contract
Input
The node consumes a message whose msg.status is an object describing the event.
    "status": {
        "event": "connect",
        "_session": { "id": "unique_session_id" },
        "config": { "userId": "12345", "language": "es" },
        "timeout": 300000
Required fields per event:
Event _session.id config timeout
connect required optional —
disconnect required — —
update required required (object) —
timeout — — optional (ms, default 300000)
get_sessions — — —
_session.id is sanitised: it must be a non-empty string of alphanumerics, underscores or dashes, with a maximum length of 100 characters. Messages that fail any validation are rejected and emitted on the error output.
Outputs
The node has two outputs:
  1. Pass-through: on a successful operation, the original msg is emitted unchanged. For get_sessions, msg.payload is set to an array of { id, config, connectedAt } records.
  2. Error: on validation failure or runtime error, a cloned message with msg.error set to a human-readable string is emitted here.
See Error routing for the dual-output behaviour and its rationale.
Events
  • connect — registers a new session. If a session with the same id already exists, the request is logged as a warning and ignored.
  • disconnect — removes a session. Disconnecting an unknown session emits a warning but does not error.
  • update — replaces the config object of an existing session. If the session does not exist, the message is sent to the error output.
  • timeout — removes every session whose connectedAt timestamp is older than msg.status.timeout milliseconds (default 300000, i.e. 5 minutes).
  • get_sessions — emits the full list of active sessions on output 1 as msg.payload. Does not modify state.
Storage model
Sessions are stored in the chosen context scope under prefix + contextKey as a plain JavaScript object keyed by sessionId:
    "<sessionId>": {
        "id": "<sessionId>",
        "config": <object or encrypted string>,
        "connectedAt": <epoch ms>
The plain-object representation is chosen so that file-backed Node-RED context stores (localfilesystem, file, etc.) serialise it correctly through JSON.stringify/JSON.parse. The in-memory legacy Map representation and the pre-Map Array representation are still readable for backwards compatibility — the first write upgrades the storage to the current format.
Encryption
When encryptConfig is enabled, the config of each session is encrypted with AES-256-CBC. The key is derived from the configured encryptionKey credential via SHA-256, and a random 16-byte IV is generated per encryption. The stored value has the form "<ivHex>:<cipherHex>".
The encryption key must be supplied via the Node-RED credentials store (a password field appears in the editor when encryptConfig is checked). Node-RED persists credentials encrypted; they are not written in plaintext to flows.json.
Missing key behaviour: if encryptConfig is enabled but no credential is provided, the node logs a warning during initialisation and disables encryption for that instance. The node never falls back to a hardcoded default key.
Decryption failure behaviour: if a stored entry cannot be decrypted (wrong key, corrupted ciphertext, malformed payload), the entry is omitted from get_sessions results and a single node.error is emitted listing the affected session IDs.
Session persistence
Starting with v0.0.3, sessions are preserved across Node-RED restarts and flow redeploys by default (preserveSessions: true). Combined with a file-backed context store (e.g. localfilesystem), this allows session state to survive process restarts without explicit migration logic.
To restore the v0.0.2 wipe-on-restart behaviour, set preserveSessions: false in the node configuration. This may be useful when you want to guarantee a clean slate and accept that previously connected clients will need to re-handshake.
Concurrency
Input messages are processed sequentially through an async-mutex Mutex. Concurrent input is queued in order of arrival; no messages are dropped. Throughput is therefore bounded by the cost of a single context read/write cycle, but ordering is deterministic.
The mutex is per-node-instance. Two fff-ws-session nodes pointing at the same contextKey are not synchronised between each other — keep them in distinct context keys, or coordinate externally.
Error routing
On any validation or processing error, the node emits the failure on both channels:
  • node.error(err, msg) — routed to Catch nodes in the flow, suitable for centralised error handling.
  • A message on output 2 with msg.error set to the failure reason.
This dual routing is intentional for v0.0.3: it preserves compatibility with deployments that wire either path. A future release (evolve-session-model) will unify routing behind a single configurable mechanism.
Examples
The examples/ directory contains two importable flows:
Reading session state from a Function node
const sessions = global.get('ws_sessions') || {};
const session = sessions[msg.sessionId];
if (session) {
    msg.user = session.config.userId;
    msg.lang = session.config.language;
    msg.created = session.connectedAt;
node.warn('Session not found: ' + msg.sessionId);
return null;
Listing all active sessions
Send a get_sessions message and read msg.payload in a downstream node:
msg.status = { event: 'get_sessions' };
// Downstream node receives:
// msg.payload = [
//     { id: 'session1', config: { ... }, connectedAt: 1700000000000 },
//     { id: 'session2', config: { ... }, connectedAt: 1700000000000 }
Conditional routing on session existence
if (sessions[msg.sessionId]) {
    return [msg, null];   // authenticated path
msg.error = 'Session not found';
return [null, msg];       // error path
Limits
  • Session count: limited by available memory. The node has been tested with up to 10,000 sessions without measurable degradation.
  • Session ID: alphanumerics, underscore and dash only; maximum 100 characters.
  • Config size: no hard limit. Large objects increase serialisation cost on every write.
  • Persistence: requires a context store that serialises with JSON.stringify (the default memory store works in-process only; use localfilesystem for cross-restart persistence).
  • Context limits: bound by the configured Node-RED context storage limits.
Troubleshooting
  • Node status shows an error: check the Node-RED runtime log for the underlying message. Common causes are invalid msg.status shape or a context store that cannot serialise the data.
  • Sessions disappear after restart: confirm preserveSessions: true (the default in v0.0.3+) and that the configured context store is persistent. The default in-memory store does not survive restarts regardless of preserveSessions.
  • Encrypted entries vanish: the encryption key changed or the ciphertext is corrupted. Look for a node.error message listing the affected session IDs.
  • Concurrent messages appear delayed: this is expected. Messages are queued by the mutex and processed in order.
Development
npm install
npm test           # mocha test suite
npm run lint       # eslint
npm run coverage   # nyc lcov + text report
The test suite uses mocha, chai and node-red-node-test-helper. Coverage is configured in .nycrc.
If you use pnpm and npm run coverage reports nyc not found, run pnpm install --include=dev to materialise the dev dependencies that are otherwise skipped.
Migration from v0.0.2
v0.0.3 introduces several behavioural changes that are safe by default but worth knowing about when upgrading:
  • preserveSessions defaults to true. Sessions on file-backed context stores now survive restarts. To restore the v0.0.2 wipe-on-restart behaviour, set preserveSessions: false.
  • The encryption key input is now visible in the editor under the Encrypt Config checkbox. Existing deployments that enabled encryption without setting a credential were silently using a hardcoded fallback; v0.0.3 disables encryption (with a warning) in that case instead.
  • Stored sessions are now a plain JSON object rather than a Map. Function-node code that used sessions.get(id) should be updated to sessions[id]. The node still reads back the legacy Map and legacy Array formats for backwards compatibility.
  • Concurrent input messages are now queued rather than dropped. Existing flows that relied on rapid duplicate suppression should explicitly debounce upstream.
  • Decryption failures now omit the affected entry from get_sessions and emit a node.error, rather than returning an empty config.
See CHANGELOG.md for the full list of changes.
Contributing
Contributions are welcome. See CONTRIBUTING.md for guidelines.
MIT. See LICENSE.
Version: 0.0.3
Updated 5 months, 3 weeks ago
3 in the last week
  • fff-ws-session
  • websocket
  • session
