node-red-contrib-felix 0.1.6
Node-RED palette of nodes for sending data to the Felix platform.
npm install node-red-contrib-felix
A collection of node-red nodes for the IOT Technology Solutions Felix platform
The use of these nodes requires that an account first be setup on the Felix platform hosted by IOT Technology Solutions. Please go to http://www.iottechnology.com to find out more about the Felix platform and FelixKnows for manufacturing.
To install the stable version run the following command in your Node-RED user directory (typically ~/.node-red):
npm i node-red-contrib-felix
Start/Restart your Node-RED instance and you should have the Felix nodes listed in the next section available in the palettes.
Develpoment and Local testing
To test a node module locally, the npm link command can be used. This allows you to develop the node in a local directory and have it linked into a local node-red install, as if it had been npm installed.
  1. In the directory containing the node’s package.json file, run:
sudo npm link
  1. In your node-red user directory, typically ~/.node-red run:
npm link node-red-contrib-felix
This creates the appropriate symbolic links between the two directories so Node-RED will discover the node when it starts. Any changes to the node’s file can be picked up by simply restarting Node-RED.
Node List
  • Felix Data (IoT Technology Solutions)
Publishing
To publish updates:
  • Increment the version number in the package.json file.
  • In the root project folder run the npm publish command.
npm publish
Descriptions
Felix-Data
This node allows a named field from the input message.payload to be posted to Felix's data collector. You must have the following information to configure the node:
  • API Key (apiKey) - the Felix API Key used to authenticate the data stream.
  • Device ID (dvcId) - the unique Device Identifier used to identify the source of the data.
  • Channel Path (channel) - the path name to assign the channel/stream of data within Felix.
  • Value (valueTag) - the name of the field within the Input Message that contains the data value, unless the payload field itself contains the data value.
  • Units (units) - optional "units" string to report with the data values.
  • URL - the URL of the data collector for the Felix platform to report the data to.
NOTE: the values in parenthesis may be set as attribute values on the input messages to overrider the configured node values.
Version: 0.1.6
Updated 9 years, 2 months ago
8 in the last week
  • felix-data
  • felix
  • felixknows
  • iot
  • iot technology solutions
  • sta
  • sta group
  • data
  • flow
  • post
  • generator
