node-red-contrib-feedparser-plus 1.1.1
A Node-RED node to get RSS Atom feeds with persistence (redis) layer
npm install node-red-contrib-feedparser-plus
Node-RED Feed Parser Plus
Buy me a beer
An enhanced and modernized fork of node-red-contrib-feedparser-x.
This version introduces better flexibility, improved developer experience, and persistent tracking of seen articles using Redis context storage.
Key Features
  • Persistent seen list using Redis — no flood of old articles on restart
  • Supports dynamic user-agent and timeout via node config or msg
  • Allows string or array of feed URLs via configurable input field
  • Two outputs: new articles and error stream
  • Node status displays internal activity for better visibility
  • Clean and modern internal implementation
Enable Redis context storage by editing your settings.js:
contextStorage: {
  default: {
    module: "memory"
  redis: {
    module: require("node-red-context-redis"),
    config: {
      host: "127.0.0.1",
      port: 6379,
      prefix: "nodered"
Note: node-red-context-redis is no longer published on npm. Install it directly via Git:
npm install git+https://github.com/node-red-hitachi/node-red-context-redis
You must have a running Redis server.
Input
  • msg.payload (or other field defined in feedField): The feed URL (string or array of strings)
  • msg.userAgent: (Optional) Override the configured user-agent string
  • msg.timeout: (Optional) Override the request timeout in milliseconds
  • msg.init_send: If true, send all items from the feed; if false, only new items
  • msg.keep_size: Number of latest items to keep track of (default: 30)
You can use an inject node to periodically feed URLs into this node.
Output
The node has two outputs:
  1. Article Output — emitted for each new article:
    • msg.topic: Article link
    • msg.payload: Article description
    • msg.article: Complete article object (see below)
  2. Error Output — emitted on failure:
    • msg.payload: Human-readable error message
The Article Object
Please refer to https://www.npmjs.com/package/feedparser#list-of-article-properties.
Node Status
The node provides runtime feedback via its status indicator:
  • fetching: <url> — fetching feed
  • parsing feed — parsing entries
  • <n> new articles — number of new entries emitted
  • no new articles — nothing new found
  • no URL, invalid URL, fetch error, status <code>, stream error, parse error, context error — respective failure statuses
Compatibility
  • Requires Node.js 20+
  • Compatible with Node-RED 3.x+
Contribute
Please follow CONTRIBUTING.md.
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at LICENSE.
Version: 1.1.1
Updated 1 year, 5 months ago
23 in the last week
  • feedparser-plus
  • atom
  • rss
  • feed
  • parse
  • Sébastien Demanou
  • 孔维鹏
  • Ray
  • Titus
