node-red-contrib-fastxml 1.5.0
A Node-RED node to parse xml strings to json and vice-versa
npm install node-red-contrib-fastxml
A Node-RED node to parse XML strings into JSON and vice-versa.
npm i node-red-contrib-fastxml
A function that converts the msg.payload to and from XML format.
Uses the fast-xml-parser library.
NOTE: it is slightly different from the core XML node in that the default header for tag attributes can be left blank which can help flatten some XML docs, but does mean they can't be reconstructed 1 for 1 in that case.
Version: 1.5.0
Updated 2 months, 3 weeks ago
80 in the last week
  • fastxml
  • xml
  • fastxml
