node-red-contrib-fast-bandwidth 0.0.3
Test network bandwidth using Fast.com
npm install node-red-contrib-fast-bandwidth
Tests your network bandwidth using Fast.com.
This will trigger on any message without looking at the payload. The only configuration parameter is upload to set whether to also test upload bandwidth. This is on by default. Turning this off will make it return faster.
The message from this node will look like this:
payload: {
    downloadSpeed: 25,
    uploadSpeed: 140,
    latency: 30,
    bufferBloat: 208,
    downloadUnit: 'Mbps',
    uploadUnit: 'Kbps',
    latencyUnit: 'ms',
    bufferBloatUnit: 'ms',
    isDone: true
NOTE: If you want to run this in Node-RED in Docker, you'll need a custom Dockerfile for Node-RED to pre-install Puppeteer / Chromium. See here:
This one worked for me:
FROM nodered/node-red:latest
USER root
# Installs latest Chromium (89) package.
RUN apk add --no-cache \
chromium \
nss \
freetype \
harfbuzz \
ca-certificates \
ttf-freefont
# Tell Puppeteer to skip installing Chrome. We'll be using the installed package.
ENV PUPPETEER_SKIP_CHROMIUM_DOWNLOAD=true \
PUPPETEER_EXECUTABLE_PATH=/usr/bin/chromium-browser
# Puppeteer v6.0.0 works with Chromium 89.
RUN yarn add [email protected]
# Add user so we don't need --no-sandbox.
RUN mkdir -p /usr/src/node-red/Downloads \
&& chown -R node-red:node-red /usr/src/node-red/Downloads
USER node-red
Version: 0.0.3
Updated 5 years, 10 months ago
Rating: 0.0
3 in the last week
  • fast-bandwidth
  • bandwidth
  • fast
