node-red-contrib-farazsms 1.0.0
FarazSMS · IranPayamak (فراز اس ام اس · ایران پیامک) — https://farazsms.com . Node-RED nodes to send SMS, OTP & pattern, check delivery, receive inbound, and manage the phonebook. Built-in rate-limit, auto-retry and error reporting.
npm install node-red-contrib-farazsms
FarazSMS · IranPayamak (فراز اس ام اس · ایران پیامک) — official Node-RED nodes for sending and receiving SMS through the FarazSMS REST API. 🌐 farazsms.com · iranpayamak.com · 📚 docs.farazsms.com/node-red
Drag-and-drop SMS into your automations: OTP, pattern, bulk send, scheduling, delivery status, inbound messages and the phonebook — with built-in rate-limiting, automatic retry and error reporting.
From Node-RED: Menu → Manage palette → Install and search for node-red-contrib-farazsms.
Or from the command line in your Node-RED user directory (~/.node-red):
Node What it does Endpoint
FarazSMS account (config) Holds your Api-Key, sender line, rate-limit & retry —
send Bulk / simple text & variable (keyword) SMS, with scheduling /ws/v1/sms/simple, /ws/v1/sms/keywords
pattern / OTP Pattern (template) SMS + one-line OTP (auto code → msg.otp) /ws/v1/sms/pattern
delivery Delivery status: single request, per-recipient items, recent list /ws/v1/send_request…
inbound Read received SMS; optional polling emits one msg per new reply /ws/v1/inbox
phonebook List phonebooks/contacts, add & bulk-upsert contacts /ws/v1/phone_book…
Quick start
  1. Drag a FarazSMS pattern / OTP node onto the canvas.
  2. Double-click it, add a FarazSMS account, paste your Api-Key (panel → Services & Web service → Access keys).
  3. Set mode = OTP, enter your pattern code, wire an inject → pattern/OTP → debug.
  4. Deploy and click inject — the code is in msg.otp, the API response in msg.payload.
Covered requirements
Send SMS · OTP · Pattern · Delivery status · Inbound · Phonebook · Scheduling · Bulk send · Rate limit · Auto-retry · Error reporting (via Catch node + msg.error) · Variable support (msg-driven attributes).
Errors
Every node raises failures through node.error(err, msg) so you can wire a Catch node; details are also on msg.error ({message, statusCode, body}).
MIT © FarazSMS · IranPayamak
Version: 1.0.0
Updated 5 months ago
  • farazsms-config
  • farazsms-send
  • farazsms-pattern
  • farazsms-delivery
  • farazsms-inbound
  • farazsms-phonebook
  • farazsms
  • iranpayamak
  • sms
  • otp
  • pattern
  • iran
  • پیامک
