node-red-contrib-fanuc-focas 0.0.2
Node-RED node for FANUC CNC data collection via FOCAS2 protocol (pure Node.js, no native libraries, adapted from pyfanuc)
npm install node-red-contrib-fanuc-focas
"Buy Me A Coffee"
A Node-RED node for collecting telemetry from FANUC CNC controllers via the FOCAS2 TCP protocol.
Pure Node.js — no Python, no native libraries, no FANUC SDK required. Works on any platform including Raspberry Pi (aarch64/arm64).
  • Connects directly to FANUC controllers over Ethernet using the FOCAS2 wire protocol
  • Selectable Function — poll only the data you need per node instance
  • Sub-type selector for Axes Data (position, servo/spindle load, feedrate)
  • Configurable Parameter and Macro variable reads by number
  • Sub-second timer resolution (millisecond companion parameters)
  • Correct run-state decoding for Series 16/18/21/0i/30i controllers
  • Series 15/15i support via config selector
  • Status indicator on each node (blue = polling, green = ok, red = error)
Supported Controllers
Series Examples
Series 0i-D / 0i-F 0i-D T (lathe), 0i-D M (mill)
Series 16i / 18i / 21i 16i-T, 18i-M
Series 30i / 31i / 32i 30i-B
Series 15 / 15i (select Series 15 in config)
Requires the FOCAS Ethernet option to be enabled on the controller (option code A02B-0207-J732 or equivalent). Default TCP port is 8193.
From Node-RED Palette Manager
Search for fanuc-focas in Menu → Manage Palette → Install.
From command line
  1. Drag a fanuc focas node onto your flow (found under the input category).
  2. Double-click it and create a new FANUC Controller config:
    • IP Address — controller Ethernet IP (e.g. 192.168.0.100)
    • FOCAS Port — default 8193
    • CNC Series — 16/18/21/0i/30i for most modern controllers
  3. Select a Function from the dropdown.
  4. Wire an Inject node (e.g. repeat every 2 seconds) to trigger polling.
  5. msg.payload contains the result for the selected function.
Functions
Function Description msg.payload fields
All Data Full combined snapshot controller, machine_state, active_program, timers, part_count, feedrate_spindle, active_alarms
Status Info Machine run state mode, run_state, motion, mstb, emergency, alarm, edit
System Info Controller identity cnc_type, mt_type, series, version, axes
Timers Accumulated time counters power_on_time, auto_operation_time, cutting_time, cycle_time
Axes Data Position / load / feed See sub-types below
Parameters Raw CNC parameters { [param_number]: value, … }
Program Number Active program running_program, main_program, running_comment, main_comment
Part Count Parts produced required_parts, lifetime_total
Alarm Messages Active alarms Array of { type, code, axis, text }
Macro Custom macro variables { [macro_number]: value, … }
Axes Data sub-types
Sub-type Description
Absolute position Axis positions in absolute coordinates
Machine position Axis positions in machine coordinates
Relative position Axis positions relative to last reset
Distance to go Remaining distance in current block
Servo load meter Per-axis servo load (%)
Spindle load meter Spindle load (%)
Spindle motor speed Actual spindle RPM
Actual feedrate Feedrate in mm/min
Timer format
Each timer returns both a machine-readable value and a formatted string:
"cutting_time": {
  "total_seconds": 53594.237,
  "formatted": "14h 53m 14.237s"
Example Payload — All Data
  "controller": {
    "cnc_type": "0",
    "mt_type": "T",
    "series": "D6G3",
    "version": "29.0",
    "axes": 32
  "machine_state": {
    "mode": "MEMory",
    "run_state": "STaRt",
    "motion": "Moving",
    "mstb": "Inactive",
    "emergency": null,
    "alarm": null,
    "edit": "Inactive"
  "active_program": {
    "running_program": "O8888",
    "main_program": "O8888",
    "running_comment": "DRIVING BAND TURNING",
    "main_comment": "DRIVING BAND TURNING"
  "timers": {
    "power_on_time":       { "total_seconds": 810844,    "formatted": "225h 14m" },
    "auto_operation_time": { "total_seconds": 183989.237,"formatted": "51h 06m 29.237s" },
    "cutting_time":        { "total_seconds": 53594.237, "formatted": "14h 53m 14.237s" },
    "cycle_time":          { "total_seconds": 47.123,    "formatted": "0h 00m 47.123s" }
  "part_count": {
    "required_parts": 500,
    "lifetime_total": 488584
  "feedrate_spindle": {
    "actual_feedrate_mm_min": 24000,
    "actual_spindle_rpm": 101
  "active_alarms": [],
  "timestamp": "2026-05-28T07:35:23.213Z"
Dynamic Override
You can override the configured function at runtime by setting properties on the incoming message:
Property Description Example
msg.function Override function "status_info"
msg.subtype Override axes sub-type "abs_pos"
msg.params Override parameter/macro numbers "6711,6712"
run_state Values
Value Series 16/18/21/0i/30i Series 15/15i
**** Reset / not in auto —
STOP Stopped in auto Stopped
HOLD Feed hold Feed hold
STaRt Auto running ✓ Auto running
MSTR Tool retract / MDI exec M/S/T executing
Note: Series 16/18/21/0i/30i run=0 means reset (not running), not STOP. Using the wrong table is a common source of misclassified machine states.
Multiple Machines
Create one FANUC Controller config node per machine, each with its own IP address. Wire separate polling chains independently:
[Inject 2s] → [fanuc-focas · Lathe 1] → [OPC UA out]
[Inject 2s] → [fanuc-focas · Lathe 2] → [OPC UA out]
Requirements
  • Node.js ≥ 14.0.0
  • Node-RED ≥ 2.0.0
  • FOCAS Ethernet option enabled on the controller
  • Network access to the controller on its FOCAS port (default 8193)
No additional npm dependencies — uses only Node.js built-ins (net, Buffer).
Technical Notes
  • FOCAS is strictly sequential. Each request must complete before the next is sent on the same TCP connection. This node correctly awaits each response before proceeding.
  • Connection per poll. A new TCP connection is opened and cleanly closed for each poll cycle, matching the FOCAS session model.
  • The FOCAS wire protocol is reverse-engineered from diohpix/pyfanuc with several bug fixes applied (valtype-2 unpack, readparam3 fallback guard, statinfo cnctype matching).
MIT
Version: 0.0.2
Updated 5 months, 3 weeks ago
25 in the last week
  • fanuc-config
  • fanuc-focas
  • fanuc
  • focas
  • cnc
  • iot
  • focas2
