node-red-contrib-ezo 1.4.0
Node to communicate with Atlas Scientific Ezo modules over I2C.
npm install node-red-contrib-ezo
This Node-Red is designed to communicate with Atlas Scientific Ezo modules over I2C.
Either use the Manage Palette option in the Node-RED Editor menu, or run the following command in your Node-RED user directory - typically ~/.node-red
npm install --unsafe-perm node-red-contrib-ezo
Designed to accept all standard commands from the Atlas Scientific documentation.
Input
All commands can be sent as a single string in msg.payload, those which have a command and input value separated by a comma can be broken into msg.command and msg.payload properties. Commands can differ from one Ezo module to another, please refer to Atlas Scientific's website for documentation. Below are a few examples of commands structured in an acceptable manner.
Since v1.3.0 msg.address can be set dynamically on input. Since v1.4.0 msg.bus can be set dynamically on input.
msg = { payload: 'L,0' };  // turns led off
msg = { command: 'L', payload: 1 };  // turns led on
msg = { command: 'L', payload: false };  // turns led off
msg = { command: 'L', payload: '1' };  // turns led on
msg = { payload: 'Status' };  // returns status
msg = { command: 'R'};  // reads probe
msg = { command: 'R', address: 105, bus: 1 }  // reads probe at address 105 and bus 1
Ouptut
Some commands such as 'Sleep', 'Factory', and 'I2C,n' do not provide a response so will not generate an output message. Most commands will generate a response containing the original command and a value, however some Ezo modules can generate multiple values in which the msg.payload will contain an array. If the output value can be parsed to a number it will be, otherwise it will be a string. Since v1.1.1 extra properties in input pass through to output.
msg = {
    topic: String,
    command: String,
    payload: String / Number / Array,
Examples of commands and responses:
Ezo Board: Temperature
Command: Status
Raw Response: 1?STATUS,P,3.28
Node Output:
msg = {
    topic: 'tempurature',
    command: 'STATUS',
    payload: [
        'P',
        '3.28',
--- OR ---
Ezo Board: pH
Command: R
Raw Response: 19.831
Node Output:
msg = {
    topic: 'ph',
    command: 'R',
    payload: 9.831,
Errors
Since v1.1.0 errors are catchable by the CATCH node. If an error occurs, a message will not be sent. Common errors include the following:
'Invalid payload!' - Error: Command must be under 32 characters.
'Syntax Error!' - Error: Ezo board did not recognize the command.
'No data to send.' - Warning: Command sent to the Ezo board was empty.
Important Note
This node uses the I2C-bus package from @fivdi. You can find his work on github: https://github.com/fivdi/i2c-bus
Version: 1.4.0
Updated 5 years, 4 months ago
Rating: 4.0 2
16 in the last week
  • ezo
  • atlas scientific
  • ezo
  • i2c
  • raspberry
  • pi
  • probe
