node-red-contrib-exchangeratesapi 1.0.1
Node-RED node for exchangeratesapi
npm install node-red-contrib-exchangeratesapi
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-exchangeratesapi, or run the following command in your Node-RED user directory, typically ~/.node-red
Wrapper exchangeratesapi.com API
Sample parameters
msg.params = {};
// msg.params.base = 'EUR'; // error on other base currency, just work on EUR
msg.params.symbols = 'KRW';
Sample flows
[{"id":"3ab86060.4ea31","type":"exchangeratesapi","z":"2422d0a1.5c053","name":"","url":"latest","base":"","symbols":"KRW","creds":"3a4aeaa5.e720d6","x":600,"y":120,"wires":[["e947f495.e22668"]]},{"id":"bc95624b.1f5fe","type":"inject","z":"2422d0a1.5c053","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":120,"wires":[["a2c60656.85d268"]]},{"id":"e947f495.e22668","type":"debug","z":"2422d0a1.5c053","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":120,"wires":[]},{"id":"a2c60656.85d268","type":"function","z":"2422d0a1.5c053","name":"","func":"msg.params = {};\n// msg.params.base = 'USD'\nmsg.params.symbols = 'KRW'\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":380,"y":120,"wires":[["3ab86060.4ea31"]]},{"id":"3a4aeaa5.e720d6","type":"exchangerates-key","name":""}]
Version: 1.0.1
Updated 4 years, 11 months ago
4 in the last week
  • exchangeratesapi
  • exchangerates-key
  • node-red-contrib-contribgen
  • exchangerate
  • exchange rate
  • 환율
  • exchange
  • exchangeratesapi
