node-red-contrib-excelsheets 1.1.1
writes multi-sheet excel files
npm install node-red-contrib-excelsheets
Overview
Features the ability to save data to multiple sheets. I found it wasn't supported in some of the other nodes already available.
To see an example, install the package, then in your Node-RED environment go to Import > Examples > node-red-contrib-excelsheets
There are two methods of structuring your incoming msg,
Standard format is this:
payload: [
        header: {
            col1: "Column 1",
            col2: "Column 2"
        items: [
                col1: "data",
                col2: "data"
        sheetName: "Sheet 1"
    {header, items, sheetName} ,
filepath: "output.xlsx"
Flexible format is this:
payload: {
    sheet1: [
        header1: "data",
        header2: "data",
        header3:{
            sub1: "data",
            sub2: "data"
    sheet2: [
        header1: "data",
        header2: "data"
    sheet3: [
        header1: "data",
        header2: "data"
When using the "Flexible" format, the headers are automatically determined from the key names. If the data in the sheet is nested in multiple objects, the path to that data is concatenated with hyphens recursively.
For the example above: sheet1, will have four headers: "header1", "header2", "header3-sub1", and "header3-sub2". sheet2 and sheet3 will just have "header1" and "header2". Furthermore, the headers do not need to be consistent, even in the same sheet. Unique headers are added to the header list when they are encountered.
The output of the node will always transform the data into the "Standard" format.
Change Log
  • 1.1.1 - Fixed problem with "Standard" input.
  • 1.1.0 - Created "Flexible" input option that parses object keys as sheet names and recursively parses multi-level objects in the row data
  • 1.0.5 - Updated docs to refer to correct msg property: filepath (not filename, )
  • 1.0.4 - Additional Example "basic w server". Cleanup and documentation.
  • 1.0.1 ~ 3 - Cleanup and documentation.
  • 1.0.0 - Original version, forked from "node-red-contrib-excel" and swapped out a different dependency.
TODO
  • Confirm where files are saved if no path is given
  • RE: above, make it default to $HOME dir if it doesn't already
Digging deeper into the dependencies, there's a really powerful package called "xlsx" <npmjs.com> that has a very rich base of features. It would be nice to create a node that uses everything available, maybe someday.
Version: 1.1.1
Updated 5 years, 4 months ago
Rating: 5.0 8
259 in the last week
  • excelsheets
  • excel
  • xlsx
