node-red-contrib-event-calc 3.3.15
Node-RED nodes for event caching and calculations
npm install node-red-contrib-event-calc
Node-RED nodes for event caching, streaming calculations, alarm management, and event framing.
Overview
This package provides a local in-memory event hub with topic-based publish/subscribe and latest-value caching for reactive data flows within Node-RED. Stream data from MQTT, OPC-UA, or any source, then perform calculations that trigger automatically when values update.
Also includes ISA-88 batch structure tracking, ISA-18.2 alarm lifecycle management, and simple event recording.
Architecture
│  event-cache (config node)                                   │
│  • Stores: Map<topic, {value, ts, metadata, previous}>      │
│  • Event emitter for topic updates                           │
│  • LRU eviction, optional TTL                                │
    │event-in │         │event-   │         │event-   │
    │         │         │topic    │         │calc     │
    │ pushes  │         │subscribes│        │multi-sub│
    │to cache │         │to topic  │        │+ expr   │
Or install directly from the Node-RED palette manager.
Core Nodes
event-cache (Config Node)
Central cache that stores topic values and manages subscriptions. Configure:
  • Max Entries: Maximum topics to cache (default: 10000). Oldest entries removed when exceeded.
  • TTL: Time-to-live in milliseconds. Set to 0 for no expiry.
event-in
Receives messages from any upstream node and pushes values to the cache.
Properties:
  • Topic Field: Where to get the topic (default: msg.topic)
  • Value Field: Where to get the value (default: msg.payload)
The original message passes through, allowing insertion into existing flows.
event-topic
Subscribes to a topic and outputs when that topic updates.
Properties:
  • Topic: Exact topic to subscribe to
  • Output Format:
    • Value only: msg.payload = value
    • Full entry: msg.payload = {value, ts, metadata}
  • Output on deploy: Emit cached values when flow starts
Dynamic control via input:
  • msg.topic: Change subscription topic
  • msg.payload = 'refresh': Output current cached value
event-calc
Subscribes to multiple topics and evaluates an expression when values update.
Properties:
  • Input Variables: Map variable names to topics
  • Expression: JavaScript expression using the variables
  • Trigger: When to calculate
    • Any input updates: Calculate on every update
    • Only when all inputs have values: Wait for all values
  • External Trigger: When enabled, any incoming message triggers calculation using cached values
Output:
  "topic": "calc/result",
  "payload": 21.5,
  "inputs": {
    "a": { "topic": "sensors/room1/temp", "value": 22, "ts": 1704000000000 },
    "b": { "topic": "sensors/room2/temp", "value": 21, "ts": 1704000001000 }
  "expression": "(a + b) / 2",
  "trigger": "sensors/room1/temp"
Event Frame Nodes
event-frame (ISA-88 Batch Structure)
Creates ISA-88 procedural model records with hierarchical parent-child linking.
ISA-88 Levels:
  • Procedure — top-level batch recipe
  • Unit Procedure — sequence within a unit
  • Operation — major processing step
  • Phase — lowest-level action
Features:
  • Trigger-based: truthy starts, falsy ends
  • Auto-generated UUIDs
  • Parent-child linking via parentLevel config or msg.frame_id chaining
  • Cascade end: ending a parent auto-ends all children recursively
  • Shared global context tracker for cross-node coordination
Output Record:
  "id": "auto-generated UUID",
  "starttime": "2024-01-15T10:30:00.000Z",
  "endtime": "9999-12-31T23:59:59.000Z",
  "name": "Mixing",
  "parent_id": "parent-uuid-or-empty",
  "level": "operation",
  "state": "running",
  "batch_id": "BATCH-001",
  "unit": "Reactor-1",
  "metadata": ""
simple-frame (Simple Event Recorder)
A simplified event frame for tracking any event with start/end time — no hierarchy, no cascade.
Properties:
  • Event Type: Category label (str/msg/flow/global/env)
  • Event Name: Descriptive name (str/msg/flow/global/env)
  • Metadata Field: Optional msg property for extra data
  • Two outputs: start and end
Output Record:
  "type": "maintenance",
  "name": "Oil Change",
  "state": "running",
  "metadata": ""
Alarm Management
event-alarm (ISA-18.2 Alarm Lifecycle)
Tracks alarms through the full ISA-18.2 lifecycle with four outputs.
Alarm States:
  • UNACK_ALM — Active + Unacknowledged (just raised)
  • ACK_ALM — Active + Acknowledged (operator acked, condition still true)
  • UNACK_RTN — Inactive + Unacknowledged (condition cleared, not yet acked)
  • NORM — Normal (fully resolved)
Lifecycle Paths:
Path A: NORM → UNACK_ALM → ACK_ALM → NORM (ack first, then clear)
Path B: NORM → UNACK_ALM → UNACK_RTN → NORM (clear first, then ack)
Properties:
  • Condition ID/Name: Alarm identifier and description
  • Input Mappings: Map variable names to cache topics (like event-calc)
  • Condition: Expression that evaluates to true/false (e.g. active == true)
  • Severity: 0-1000 scale
  • 4 Outputs: raised, acknowledged, cleared, resolved
Actions (via msg.payload):
  • { action: "ack", source: "topic" } — Acknowledge specific alarm
  • { action: "ack_all" } — Acknowledge all active alarms
  • { action: "list" } — List all active alarms
Utility Nodes
event-flatten
Flattens nested objects into individual topic/value pairs for the cache.
event-preview
Preview cached values directly in the Node-RED editor.
event-simulator
Generates simulated data for testing. Supports sine waves, random values, and ramps.
event-chart
Real-time charting node for visualizing cached event data.
Built-in Functions (event-calc)
Math
Function Description
min(a, b, ...) Minimum value
max(a, b, ...) Maximum value
abs(x) Absolute value
sqrt(x) Square root
pow(base, exp) Power
log(x), log10(x) Logarithms
floor(x), ceil(x) Rounding
sin(x), cos(x), tan(x) Trigonometry
PI, E Constants
Aggregation
sum(a, b, ...) Sum of values
avg(a, b, ...) Average of values
count(a, b, ...) Count of values
Utility
round(value, decimals) Round to N decimals
clamp(value, min, max) Constrain to range
map(value, inMin, inMax, outMin, outMax) Scale between ranges
lerp(a, b, t) Linear interpolation
ifelse(cond, trueVal, falseVal) Conditional
between(value, min, max) Range check (returns boolean)
delta(current, previous) Difference
pctChange(current, previous) Percentage change
Change Detection
now() Current timestamp in milliseconds
prev('varName') Previous value of a variable
hasChanged('varName') true if value differs from previous (false on first message)
timeSinceLastChange('varName') Milliseconds since the value last changed
Date/Time
hour() Current hour (0-23)
minute() Current minute (0-59)
second() Current second (0-59)
day() Day of week (0=Sun, 1=Mon, ..., 6=Sat)
dayOfMonth() Day of month (1-31)
month() Month (1-12)
year() Full year (e.g. 2026)
isWeekday() true if Monday-Friday
isWeekend() true if Saturday or Sunday
hoursBetween(start, end) true if current hour is within range (wraps midnight)
Expression Examples
Expression Description
a + b Sum
avg(a, b) Average
max(a, b, c) Maximum
sqrt(a*a + b*b) Pythagorean
round(a, 2) Round to 2 decimals
clamp(a, 0, 100) Constrain 0-100
map(a, 0, 1023, 0, 100) Scale ADC to %
ifelse(a > b, 'high', 'low') Conditional
hasChanged('temp') Did temperature just change?
temp - prev('temp') Delta from previous value
isWeekday() && hoursBetween(8, 18) During business hours?
API (for custom nodes)
The event-cache node exposes methods for programmatic access:
const cache = RED.nodes.getNode(configId);
// Set a value
cache.setValue('topic/path', 42, { source: 'sensor' });
// Get a value
const entry = cache.getValue('topic/path');
// { value: 42, ts: 1704000000000, metadata: { source: 'sensor' }, previous: { value: 40, ts: ..., metadata: ... } }
// Subscribe to updates
const subId = cache.subscribe('sensors/room1/temp', (topic, entry) => {
    console.log(`${topic} = ${entry.value}`);
// Unsubscribe
cache.unsubscribe(subId);
// Get all topics
const topics = cache.getTopics();
// Clear cache
cache.clear();
HTTP Admin Endpoints
GET  /event-cache/:id/stats    - Cache statistics
GET  /event-cache/:id/topics   - List all topics
POST /event-cache/:id/clear    - Clear cache
GET  /event-frame/tracker      - Current batch tracker state
GET  /event-alarm/:id/alarms   - Active alarms for a node
Personal Use License - See LICENSE file.
Version: 3.3.15
Updated 8 months, 2 weeks ago
License: SEE LICENSE IN LICENSE
30 in the last week
  • event-cache
  • event-in
  • event-topic
  • event-calc
  • event-flatten
  • event-preview
  • event-simulator
  • event-chart
  • event-frame
  • event-alarm
  • simple-frame
  • events
  • cache
  • reactive
  • calculation
  • streaming
