node-red-contrib-eufy-security 0.1.1
Eufy security node for Node RED
npm install node-red-contrib-eufy-security
Description
Node-RED contribution package for Eufy security devices, based on eufy-security-client
Node RED plugin wrapper around eufy-security-client library to access and control by connecting to the Eufy cloud servers and local/remote stations over P2P.
Note
Not all events and commands have been added/tested, check list below. Full list can be found here.
Tested events:
  • connect
  • captcha request
  • close
  • push connect
  • push close
  • push message
  • device added
  • station added
  • station command result
  • station guard mode
  • station current mode
  • station property changed
  • station raw property changed
  • device property changed
  • device raw property changed
Tested commands:
  • connect
  • close
  • get config
  • get version
  • is push connected
  • is connected
  • refresh cloud data
  • get stations
  • get devices
  • get camera max livestream duration
Tested commands with props:
  • is station connected (stationSN)
  • get station (stationSN)
  • get device (deviceSN)
  • connect to station (stationSN)
  • set camera max livestream duration (seconds)
Not tested commands:
  • get station device (stationSN, channel)
How to use
  1. Find eufy-security node in network group and add it to the flow, connect with inject node as input and debug node as output;
  2. Configure eufy-config by providing your cloud credentials;
  3. (optional) Select events to track;
  4. Deploy flow;
  5. If all configured correctly you should see Connected under the node;
  6. This node will send events as objects to output:
  pyload: {
    event,
    station,
    device,
    result,
    currentMode,
    command,
    error,
Suported events:
  • connect
  • close
  • push connect
  • push close
  • push message
  • station added
  • station removed
  • device added
  • device removed
  • device connect
  • device close
  • tfa request
  • captcha request
  • connection error
  • cloud livestream start
  • cloud livestream stop
  • station livestream start
  • station livestream stop
  • station download start
  • station download finish
  • station rtsp url
  • station alarm event
  • device crying detected
  • device sound detected
  • device pet detected
  • device motion detected
  • device person detected
  • device rings
  • device locked
  • device open
Also you can send commands to this node in this form:
  pyload: {
    command,
    stationSN,
    deviceSN,
    name,
    value,
    verifyCode,
    seconds,
    p2pConnectionType,
    channel,
Supported commands with arguments (? means optional):
  • set station property (stationSN, name, value)
  • set device property (deviceSN, name, value)
  • get config
  • get version
  • is push connected
  • is connected
  • connect (?loginOptions)
  • close
  • connect to station (stationSN, p2pConnectionType)
  • get stations
  • get devices
Version: 0.1.1
Updated 3 years, 6 months ago
Rating: 4.0 1
11 in the last week
  • eufy-config
  • eufy-security
  • eufy
  • security
