node-red-contrib-escape-arc 0.6.2
Node-RED nodes for ARC: monitor game activity and trigger actions.
npm install node-red-contrib-escape-arc
Node-RED nodes for Automation Room Control (ARC). Use them to watch live game activity and trigger ARC actions from your flows.
Detailed release notes are in CHANGELOG.md.
What You Need
  • Node-RED 2.0+
  • ARC Core running and reachable on your network
  • ARC connection node-red enabled in Settings -> Connections
# Palette Manager (recommended)
# CLI
Restart Node-RED after install.
Quick Start
  1. Add an ARC Config node and set the ARC host (computer name or IP).
  2. Add an input node (ARC Timer, ARC State, or ARC Objective) and pick your game.
  3. Add an ARC Output node to send actions back to ARC.
  4. Deploy and test.
Example action message:
msg.action = {
  type: "send_message",
  targets: ["display-main"],
  format: "text",
  text: "Welcome team!",
  durationMs: 12000
Node What it does
ARC-config Shared ARC connection settings and game list lookup.
ARC-input Streams all ARC events, with optional filtering.
ARC-state Emits game state changes for one game.
ARC-timer Emits timer updates every N seconds or at thresholds.
ARC-objective Emits objective lifecycle events (activate, complete, reset, fail).
ARC-output Sends ARC actions, display commands, or custom events.
ARC-boolean Converts messages into a simple true/false match result.
Output Modes
  • ARC action: Send game.action messages (or use a preset action).
  • Display command: Send display control commands.
  • Custom event: Send your own custom event and payload.
Notes
  • ARC host defaults are 127.0.0.1 and port 3000.
  • The ARC path is fixed by this package.
Release Notes
See CHANGELOG.md.
Version: 0.6.2
Updated 1 month, 2 weeks ago
Rating: 5.0 2
5 in the last week
  • ARC-config
  • ARC-input
  • ARC-output
  • ARC-boolean
  • ARC-state
  • ARC-timer
  • ARC-objective
  • escape room
  • iot
  • arc
  • automation
