node-red-contrib-epic-ignition-nodes 1.5.6
Adds support for reading and writing to tags in Ignition
npm install node-red-contrib-epic-ignition-nodes
Node-RED for Ignition
Overview
Node-RED nodes for interfacing to Ignition by Inductive Automation. Allows for the reading and writing of tags configured in Ignition.
Requires Node-RED Ignition Module and Ignition 7.9.3 or later.
These nodes are provided for installation version compatibility when using grv-epic-pr1-2.0.x firmware which includes ignition and ignition-edge gateway software 7.9.14.
For ignition 8.0 installation use the updated node-red-contrib-ignition-nodes
Run the following command in your Node-RED user directory:
npm install node-red-contrib-ignition-nodes
The Tag Read node can read the value of any tag in Ignition. This includes all Gateway tags (OPC, memory, expression, SQL, derived, UDTs) and System tags.
The Tag Write node can write to tags in Ignition. This will only work with tags that are configured with write privileges.
Copyright and License
Copyright 2017 Ignition Module Development Community
Licensed under the Apache 2.0 license.
Version: 1.5.6
Updated 6 years, 9 months ago
5 in the last week
  • ignition-tag-read
  • ignition-tag-write
  • ignition-server
  • tag
  • tag read
  • tag write
  • hmi
  • scada
  • Ignition
  • Inductive Automation
