node-red-contrib-envisalink-ademco 1.1.1
Honeywell Ademco alarm system support for node-red using the EnvisaLink module
npm install node-red-contrib-envisalink-ademco
Node-RED Modbus License Standard - JavaScript Style Guide NPM version
Ademco alarm systems integration with Node-RED using the EnvisaLink hardware.
This node allows you to listen to state changes in your Honeywell Ademco alarm as well as sending commands such as arming and disarming of your alarm.
Run the following command for global install
npm install -g node-red-contrib-envisalink-ademco
How to use
The output node, with which you send commands, takes a raw TPI command as a string. Please refer to the TPI documentation for a full list of commands. For example, to arm partition 1 using the code 9999 you would use the command '99992' to arm. And '99991' to disarm. All commands sent to the Ademco are as if you were typing directly on the remove alarm keypad.
Flow example credit goes to Patrik Akerfeldt Flow Example
Authors
Chris Thierman
based on DSC version by:
Patrik Ã…kerfeldt
History
  • based on work by [Patrik Akerfeldt]
  • based on work from NodeAlarmProxy.
Version: 1.1.1
Updated 7 years, 2 months ago
8 in the last week
  • envisalink-controller
  • envisalink in
  • envisalink out
  • ademco
  • honeywell
  • alarm
  • envisalink
