node-red-contrib-env 1.0.2
Node-RED Node to read environment variables.
npm install node-red-contrib-env
Node-RED enviroment variable reader
Reads enviroment variables from the Node-RED server process using the process.env node variable.
Type
yarn add node-red-contrib-env
or
npm install --save node-red-contrib-env
to avoid yarn.
Behavior
There are three ways the node tries to specify the environment variable name which shoud be need in that order
  1. Use the key specified in the node config.
  2. Use the payload from the incomming message.
  3. Use the topic from the incomming message.
Version: 1.0.2
Updated 9 years, 10 months ago
699 in the last week
  • process-env
  • process
  • env
