node-red-contrib-entitypreviousdata 1.0.4
A custom Node-RED node that gives the previous entity information.
npm install node-red-contrib-entitypreviousdata
A custom Node-RED node that retrieves the previous entity data from a PostgreSQL database for a given entity and timestamp.
Or install directly from the Node-RED Manage Palette by searching for node-red-contrib-entitypreviousdata.
The Entity Previous Data node queries a PostgreSQL EntityData table to find the most recent record for a given EntityId that occurred before the provided TimeStamp.
Input (msg.payload)
Field Type Description
EntityId string The entity to look up
TimeStamp string/date The current timestamp; the node finds the record just before this
Outputs
  • Output 1 (Success): msg.payload contains the original payload merged with msg.payload.metadata.previousData and msg.payload.metadata.previousTimestamp.
  • Output 2 (Failure): msg.payload with msg.metadata.error set if no record is found or a DB error occurs.
Field Description
Host PostgreSQL host (default: localhost)
Port PostgreSQL port (default: 5432)
User Database user (default: postgres)
Password Database password
Database Database name (default: testdb)
Requirements
  • Node.js >= 12
  • Node-RED >= 1.0.0
  • PostgreSQL database with an EntityData table containing EntityId, TimeStamp, and Data columns
MIT
Version: 1.0.4
Updated 5 months, 2 weeks ago
  • Entity Previous Data
  • postgresql
  • entitypreviousdata
  • database
