node-red-contrib-emberplus-gadget 0.1.10
Node-RED node for Ember+ protocol communication using node-emberplus
npm install node-red-contrib-emberplus-gadget
A Node-RED node for communicating with devices using the Ember+ protocol. This node is currently only for reading values.
Install from the Node-RED palette, or run:
  1. Add an Ember+ Gadget node to your flow.
  2. Configure the node with:
    • Host: The hostname or IP address of your Ember+ server
    • Port: The port number (default: 9000)
    • OID: The OID path you want to read (e.g., 997.1.2) or use msg.iod
    • Output format: Choose how the result is output:
      • array (default): [OID, Value, Description]
      • object: { oid, value, description }
      • value: Value only
  3. Connect the node to other nodes in your flow.
  4. Deploy the flow.
The node will output the value of the specified OID in the message payload.
  • Connects to Ember+ servers
  • Reads OID values (manual OID entry)
  • Fast, direct lookup (no tree search)
  • Multiple output formats (array, object, value)
  • Automatic connection management
  • Error handling
Requirements
  • Node-RED
  • Ember+ server (with known OIDs)
  • node-emberplus (installed automatically)
MIT
Contributing
Pull requests and issues are welcome!
Examples
Example flows can be found in the examples directory. Import them into Node-RED to get started quickly.
Changelog:
  • v0.1.5: Changed the Node registration so there are 2 nodes now instead of a duplicate.
Version: 0.1.10
Updated 1 month, 3 weeks ago
137 in the last week
  • emberplus-gadget-config
  • emberplus-gadget
  • ember+
  • emberplus
  • protocol
  • gadgets
