node-red-contrib-emberplus 1.0.5
Interface to Ember+ automation standard
npm install node-red-contrib-emberplus
Simple Ember+ client node for broadcast automation (LAWO, DHD, etc.). Ember+ is open source and implemented in hard- and software products. More information can be found here: Ember+ control protocol
emberplus-server node
First of all there is at least one emberplus-server node to be configured. Simply set an IP address and a port (usually 9000). It is possible to add several emberplus-server nodes for different targets (for example all your audio mixers).
emberplus node
Each emberplus node is associated with a previously configured emberplus-server node. Further an object path can be selected if the node should subscribe a specific object in the Ember+ tree. If you don't know the path, click on the looking glass symbol on the right.
Input Pin
The input pin of the node takes two types of message payloads:
  • msg.payload takes the plain value to be set to the specified path. Example:
true
  • msg.payload contains path and value to the specified node. Example:
{"full":{"path":"0.1.0","value":true}}
Output Pin
The data format of the output pin can be configured:
  • plain: msg.payload contains the plain value from the Ember+ object
  • contents: msg.payload.contents contains the contents Ember+ object from the underlying node-emberplus client
  • full: msg.payload.full contains the full Ember+ object from the underlying node-emberplus (including the device path)
If needed the inital state may be sent by clicking a corresponding checkbox.
To Be Done
  • Invoking functions
  • Setting matrix connections
  • Ember+ server
Version: 1.0.5
Updated 5 years, 5 months ago
License: GPL-3.0-or-later
13 in the last week
  • ember+
  • emberplus-server
  • Ember+
  • Lawo
  • Ember Plus
  • Studio
  • Automation
  • Broadcast
