node-red-contrib-elt 1.0.28
Node-RED nodes for ELT operations with automatic Singer.io plugin management and schema-driven configuration
npm install node-red-contrib-elt
A collection of Node-RED nodes for ELT (Extract, Load, Transform) operations using Singer.io taps and targets with automatic plugin management and schema-driven configuration.
  • Extractor Node: Extract data from various sources using Singer.io taps
  • Loader Node: Load data to various destinations using Singer.io targets
  • Automatic Plugin Management: Virtual environments are set up automatically
  • Schema-Driven Configuration: Dynamic UI forms based on plugin schemas
  • File-Based Communication: Extractor saves results to files, loader reads from them
  • Retry Logic: Configurable retry attempts and timeouts
  • Visual Status Indicators: Real-time status with attempt counters
Via Node-RED Palette Manager (Recommended)
  1. Open Node-RED in your browser
  2. Go to Menu → Manage palette
  3. Click Install tab
  4. Search for node-red-contrib-elt
  5. Click Install
Via Command Line
Quick Start
  1. Add Extractor Node:
    • Drag extractor node from the palette
    • Configure plugin (e.g., tap-postgres)
    • Set database connection details
  2. Add Loader Node:
    • Drag loader node from the palette
    • Configure plugin (e.g., target-postgres)
    • Set destination database details
  3. Connect Nodes:
    • Wire extractor output to loader input
    • Deploy the flow
Available Plugins
Extractors (Taps)
  • tap-postgres: Extract from PostgreSQL databases
Loaders (Targets)
  • target-csv: Load to CSV files
  • target-postgres: Load to PostgreSQL databases
Each node provides a dynamic configuration form based on the selected plugin's schema:
  • Database Connection: Host, port, database name, credentials
  • Retry Settings: Max attempts, timeout values
  • Plugin-Specific Options: Varies by plugin type
Environment Setup
The package automatically sets up Python virtual environments with required Singer.io plugins during installation. If you encounter environment issues:
  1. Go to Menu → Manage palette
  2. Remove the node-red-contrib-elt package
  3. Install it again to trigger environment setup
Usage Example
[inject] → [extractor] → [loader] → [debug]
  1. Inject Node: Triggers the extraction
  2. Extractor Node: Extracts data and saves to file
  3. Loader Node: Reads file and loads to destination
  4. Debug Node: Shows completion status
Troubleshooting
Environment Issues
  • Error: "Environment not ready - reload module from palette"
  • Solution: Remove and reinstall the package via palette manager
Configuration Issues
  • Error: "No configuration found"
  • Solution: Double-click node and configure plugin settings
Connection Issues
  • Error: "Failed to connect"
  • Solution: Verify database credentials and network connectivity
Requirements
  • Node-RED: v2.0.0 or higher
  • Node.js: v14.0.0 or higher
  • Python: v3.6 or higher
  • virtualenvwrapper: For automatic environment management
Support
  • Issues: GitHub Issues
  • Documentation: See DEVELOPER.md for technical details
  • Examples: Check the /examples directory
ISC License
node-red, elt, etl, data-pipeline, singer, tap-postgres, target-postgres, meltano
Version: 1.0.28
Updated 1 year, 2 months ago
  • extractor-node
  • loader-node
  • elt
  • etl
  • tap-postgres
  • target-postgres
  • data-pipeline
  • meltano
