node-red-contrib-elliptic-curve-cryptography 0.0.2
Simple ECC cryptography with BIP 39 wordlist
npm install node-red-contrib-elliptic-curve-cryptography
I need a Node in NodeRed that generate similar result what this command generate in linux. xxd creates a hex dump of a given file or standard input. It can also convert a hex dump back to its original binary form. Reverse (-r) operation: convert (or patch) hexdump into binary. Also (-p) known as plain hexdump style.
On the commandline:
echo -n '16432a207785ec5c4e5a226e3bde819d' | xxd -r -p | sha256sum -b | awk '{print $1}'
This command outputs:
7aa0c5dba5ab65301e23532af8a1730d40068cd32ebafaa5765de0d9bd9ef60f
The node "hash-sha256-hex" has dependencies with "eosjs-ecc" "4.0.7" from https://github.com/IT-Berater/eosjs-ecc for the hash sha256 (binary) function.
What this command does is first given an hexadecimal string, convert it to binary, and display the sha256 hash of the binary data in hexadecimal.
Different libraries put simply the output with sha256 hash the string.
If you need the normal sha256 with different hash output, you can use the node-red-contrib-cryptography Node:
echo -n '16432a207785ec5c4e5a226e3bde819d' | ./sha256sum
This command other outputs:
dc88aa37112eec5b02c3b082cb581ee567a9de1c7d4a50851bd3c6e6707c96cc
BIP39 Wordlist
The node "bip39 wordlist" used the dependencies "bip39": "3.0.3". You can simple generate a BIP39 Wordlist with 12 words. Its gnerate a hex Seed for this words.
You can typed your onwn words and create the Checksum and Seed. The node validates this input words.
Sample Flow: image
Gui:
Version: 0.0.2
Updated 6 years, 2 months ago
Rating: 5.0 2
3 in the last week
  • hash sha256 hex
  • bip39 wordlist
  • nodered
  • ecc
  • sha-256
  • sha256
  • eosjs-ecc
  • eosjsecc
  • eosjs
  • elliptic
  • crypto
  • hash
  • crypt
  • bitcoin
  • BIP39
  • bip 39
  • BIP-39
  • wordlist
  • cryptography
  • ripemd
  • ripemd160
  • ripemd-160
  • hash
