node-red-contrib-elevate-advanced-ftp 3.0.2
A Node-RED node to and Advanced FTP Client
npm install node-red-contrib-elevate-advanced-ftp
A Node-RED node for advanced FTP operations, with extended runtime control and logging capabilities.
๐Ÿ› ๏ธ Forked and maintained by Elevate IT, based on the original work by anversoft.
โœจ What's New in This Fork?
This fork introduces a new operation:
โœ… PUTRENAME
A convenient one-step action that first uploads a file (PUT) and immediately renames it on the server (RENAME). This is especially useful for workflows where you want to avoid processing partially uploaded files on the server.
๐Ÿ“ฆ Installation
Using npm:
Run the following in your Node-RED user directory (usually ~/.node-red):
Then restart Node-RED.
Using the Node-RED Palette:
  • Open Node-RED
  • Go to Menu โ†’ Manage palette โ†’ Install
  • Search for node-red-contrib-elevate-advanced-ftp and install
โš™๏ธ Usage
The node supports a variety of FTP operations. These can be set either statically in the editor or dynamically at runtime via msg.operation.
Supported operations:
  • status
  • pwd
  • system
  • list
  • get
  • put
  • append
  • rename
  • delete
  • mkdir
  • rmdir
  • โœ… putrename โ† New!
You can modify paths, filenames, and other parameters dynamically via msg properties.
๐Ÿงช Example Flow
Here's an example of how to use the FTP Client node to perform different FTP operations dynamically:
[PASTE FULL EXAMPLE FLOW JSON HERE]
๐Ÿ”’ FTP Logger
Also included is an FTP Logger node that periodically logs data to files, rotates them, and uploads to an FTP server.
๐Ÿ™Œ Acknowledgements
This project uses the following libraries:
  • node-ftp โ€“ Asynchronous FTP client for Node.js.
  • fs-extra โ€“ File system utilities with promise support and enhancements.
๐Ÿ“„ License
Apache License 2.0 โ€“ See LICENSE.
๐Ÿค Contributing
We welcome issues and pull requests!
Open an issue or PR at: https://github.com/Elevate-IT/node-red-contrib-elevate-advanced-ftp/issues
๐Ÿ‘ฅ Contributors
Thanks to all contributors past and present!
Original project:
Fork maintained by: Elevate IT
Version: 3.0.2
Updated 1 year, 4 months ago
License: Apache
  • advanced-ftp-config
  • advanced-ftp
  • advanced-ftp-logger
  • node red
  • node red ftp
  • ftp npm
  • npm ftp
  • ftp
  • ftp client
  • ftp client server
  • advanced
  • advanced ftp
  • advanced-ftp
  • nodejs
