node-red-contrib-ejbca 1.0.15
Node-RED Nodes to request, renew and revoke certificates via a RESTful API with EJBCA
npm install node-red-contrib-ejbca
node-red-contrib-ejbca Integration Package
EJBCA Logo
This Node-RED package provides a set of nodes for integrating with the EJBCA (Enterprise JavaBeans Certificate Authority) using the EJBCA REST (and EST for pkcs10 enrollment) interface. With these nodes, you can automate certificate management tasks and create custom certificate workflows within Node-RED.
To setup EJBCA follow the documentation on https://www.ejbca.org
⚠️ Warning: ⚠️ Use this node with care! Some nodes expose credentials and key material to the flow (and thus to the memory). Therefore you should only use it in a trusted environment.
Table of Contents
To install this Node-RED package, follow these steps:
  1. Open your Node-RED instance.
  2. Go to the menu on the top-right corner and select "Manage palette."
  3. In the "Install" tab, search for "node-red-contrib-ejbca" and click "Install" to add the package to your Node-RED instance.
  4. After installation, restart Node-RED for the changes to take effect.
Before using the nodes, you must configure the EJBCA connection by creating an "EJBCA Configuration" node. The configuration should have the following structure:
    "subjects": [
            "property": "CN",
            "prop_value": "",
            "prop_required": true,
            "prop_modifiable": true
            "property": "O",
            "prop_value": "Campus Schwarzwald",
            "prop_modifiable": false
            "property": "OU",
            "prop_value": "Showcase Robot",
            "property": "C",
            "prop_value": "DE",
    "subject_alternative_names": [],
    "profile": {
        "hostname": "campuspki.germanywestcentral.cloudapp.azure.com",
        "certificate_profile_name": "KF-CS-ShowcaseRobot-MQTT-CertProfile",
        "end_entity_profile_name": "KF-CS-ShowcaseRobot-MQTT-Client-EndEntity",
        "certificate_authority_name": "KS-CS-ShowcaseRobot-MQTT-CA",
        "est_alias": "est_node_red_alias",
        "username": {
            "value": "",
            "auto_generated": false
        "enrollment_code": {
            "required": true,
            "auto_generated": false,
            "minimum_bits": 0
        "mail": {
            "use": true,
            "required": false,
            "modifiable": false
This package includes the following nodes:
  • configure-entity: This node handles the configuration related to a PKCS10 signing request.
  • create-csr: This node is used to create a PKCS10 Certificate Signing Request (CSR) which is a request for a digital certificate.
  • ejbca-config (config-node): This is a configuration node that stores the connection settings and certificate related settings for the EJBCA instance.
  • ejbca-status: This node is used to check the status or health of the EJBCA instance.
  • enroll-keystore: This node enrolls a keystore, which is a container for keys and certificates.
  • enroll-pkcs10: This node is used to enroll or request a certificate using a PKCS#10 Certificate Signing Request ( CSR).
  • export-keys: This node is used to export cryptographic keys.
  • generate-keys: This node generates cryptographic keys.
  • generate-p12: This node generates a PKCS#12 (P12) file, which typically includes a private key and its associated certificate.
  • revocation-status: This node checks the revocation status of a certificate.
  • revoke: This node is used to revoke a certificate.
  • search-certificates: This node is used to search for certificates within the EJBCA instance.
  • store-certificate: This node stores a DER string to a certificate on the local drive
Usage Examples
To help you get started, here are some usage examples and workflows that demonstrate how to use the nodes in this package:
Example 1: Certificate Enrollment Workflow (REST)
Enrollment workflow
        "id": "4a8f91e0c158c01b",
        "type": "group",
        "z": "c24ed033437e3a9c",
        "style": {
            "label": true
        "nodes": [
            "cd77f7e51ee95a69",
            "51ed0a3da61da078",
            "dcc9fdfd9f9fe965",
            "ccc6d6bf75331f5d",
            "bab0272bb0b06c43",
            "5aa108b5dac99c07",
            "0f23e62bc183354d",
            "2894c040a64d63c7",
            "9f55b1cdc9c2bd71",
            "b579dd08a623fa1e",
            "f457e9b4239a4f4b",
            "9cad83db3f458788",
            "82c1edab45b9f80f",
            "d605822ff1bace88",
            "868049c2e421cc9a",
            "1365558a7084ce5d"
        "x": 74,
        "y": 879,
        "w": 792,
        "h": 502
        "id": "cd77f7e51ee95a69",
        "type": "generate-keys",
        "g": "4a8f91e0c158c01b",
        "bitLength": "2048",
        "x": 440,
        "y": 1040,
                "bab0272bb0b06c43",
                "9cad83db3f458788",
                "51ed0a3da61da078"
        "id": "51ed0a3da61da078",
        "type": "configure-entity",
        "ejbcaConfig": "4eedf14773d23515",
        "CN": "test",
        "O": "Campus Schwarzwald",
        "OU": "Showcase Robot",
        "C": "DE",
        "L": "",
        "ST": "",
        "postalCode": "",
        "streetAdress": "",
        "serialNumber": "",
        "emailAdress": "",
        "givenName": "",
        "surName": "",
        "initials": "",
        "title": "",
        "description": "",
        "ipAddress1": "",
        "ipAddress2": "",
        "ipAddress3": "",
        "Uri1": "",
        "Uri2": "",
        "Uri3": "",
        "Dns1": "",
        "Dns2": "",
        "Dns3": "",
        "x": 440,
        "y": 1100,
                "5aa108b5dac99c07",
                "f457e9b4239a4f4b"
        "id": "dcc9fdfd9f9fe965",
        "type": "enroll-pkcs10",
        "tls": "7f5a2ba045b1a9b1",
        "client_type": "REST",
        "username_fieldType": "str",
        "username": "node_red_test_user_fhk",
        "csrInfo_fieldType": "msg",
        "csrInfo": "ejbca.csr",
        "enrollment_code": "foo123",
        "x": 440,
        "y": 1220,
                "2894c040a64d63c7",
                "ccc6d6bf75331f5d"
        "id": "ccc6d6bf75331f5d",
        "type": "generate-p12",
        "outputDirectory_fieldType": "str",
        "outputDirectory": "/Users/florianhandke/Downloads",
        "fileName_fieldType": "str",
        "fileName": "x509_cert_1",
        "p12_password": "foo123",
        "x": 440,
        "y": 1280,
                "9f55b1cdc9c2bd71"
        "id": "bab0272bb0b06c43",
        "type": "debug",
        "name": "debug generate keys",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 680,
        "y": 1000,
        "id": "5aa108b5dac99c07",
        "type": "debug",
        "name": "debug entity configuration",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 700,
        "y": 1100,
        "id": "0f23e62bc183354d",
        "type": "debug",
        "name": "debug create CSR",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 670,
        "y": 1160,
        "id": "2894c040a64d63c7",
        "type": "debug",
        "name": "debug pkcs#10 request",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 690,
        "y": 1220,
        "id": "9f55b1cdc9c2bd71",
        "type": "debug",
        "name": "debug P12 generation",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 680,
        "y": 1280,
        "id": "b579dd08a623fa1e",
        "type": "inject",
        "name": "trigger",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 170,
        "y": 1040,
                "cd77f7e51ee95a69"
        "id": "f457e9b4239a4f4b",
        "type": "create-csr",
        "subjectAltnames_fieldType": "msg",
        "subjectAltnames": "ejbca.subject_alternative_names",
        "subjects_fieldType": "msg",
        "subjects": "ejbca.subjects",
        "privateKey_fieldType": "msg",
        "privateKey": "ejbca.privateKey",
        "publicKey_fieldType": "msg",
        "publicKey": "ejbca.publicKey",
        "x": 430,
        "y": 1160,
                "dcc9fdfd9f9fe965",
                "0f23e62bc183354d"
        "id": "9cad83db3f458788",
        "type": "export-keys",
        "privatefileName_fieldType": "str",
        "privatefileName": "private_key",
        "publicfileName_fieldType": "str",
        "publicfileName": "public_key",
        "x": 670,
        "y": 1040,
        "id": "82c1edab45b9f80f",
        "type": "store-certificate",
        "certificate_fieldType": "msg",
        "certificate": "ejbca.enroll_pkcs10.certificate",
        "fileName": "testcert",
        "outputFormat": "DER",
        "fileExtension": "crt",
        "x": 440,
        "y": 1340,
                "d605822ff1bace88"
        "id": "d605822ff1bace88",
        "type": "debug",
        "name": "debug export cert",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 670,
        "y": 1340,
        "id": "868049c2e421cc9a",
        "type": "comment",
        "name": "REST PKCS10 enrollment",
        "info": "",
        "x": 210,
        "y": 920,
        "id": "1365558a7084ce5d",
        "type": "comment",
        "name": "Change your TLS configuration, output directories etc. to your need",
        "info": "",
        "x": 340,
        "y": 960,
        "id": "4eedf14773d23515",
        "type": "ejbca-config-3",
        "name": "KF-CS-ShowcaseRobot-MQTT-Client-EndEntity",
        "ejbcaConf": "{\n    \"subjects\": [\n        {\n            \"property\": \"CN\",\n            \"prop_value\": \"\",\n            \"prop_required\": true,\n            \"prop_modifiable\": true\n        },\n        {\n            \"property\": \"O\",\n            \"prop_value\": \"Campus Schwarzwald\",\n            \"prop_required\": true,\n            \"prop_modifiable\": false\n        },\n        {\n            \"property\": \"OU\",\n            \"prop_value\": \"Showcase Robot\",\n            \"prop_required\": true,\n            \"prop_modifiable\": false\n        },\n        {\n            \"property\": \"C\",\n            \"prop_value\": \"DE\",\n            \"prop_required\": true,\n            \"prop_modifiable\": false\n        }\n    ],\n    \"subject_alternative_names\": [],\n    \"profile\": {\n        \"hostname\": \"campuspki.germanywestcentral.cloudapp.azure.com\",\n        \"certificate_profile_name\": \"KF-CS-ShowcaseRobot-MQTT-CertProfile\",\n        \"end_entity_profile_name\": \"KF-CS-ShowcaseRobot-MQTT-Client-EndEntity\",\n        \"certificate_authority_name\": \"KS-CS-ShowcaseRobot-MQTT-CA\",\n        \"est_alias\": \"est_node_red_alias\",\n        \"username\": {\n            \"value\": \"\",\n            \"auto_generated\": false\n        },\n        \"enrollment_code\": {\n            \"required\": true,\n            \"auto_generated\": false,\n            \"minimum_bits\": 0\n        },\n        \"mail\": {\n            \"use\": true,\n            \"required\": false,\n            \"modifiable\": false\n        }\n    }\n}"
        "id": "7f5a2ba045b1a9b1",
        "type": "tls-config",
        "cert": "",
        "key": "",
        "ca": "",
        "certname": "NodeRedRestAdmin001.cert.pem",
        "keyname": "NodeRedRestAdmin001.key.pem",
        "caname": "ca-chain.cert.pem",
        "servername": "",
        "verifyservercert": true,
        "alpnprotocol": ""
Example 2: Certificate Enrollment Workflow (EST)
PKCS10_Enrollment_EST
For EST enrollment you need to an EST alias to your EJBCA-Config in profile.est_alias
        "id": "5be4c59e7ae77b49",
        "type": "group",
        "style": {
            "stroke": "#999999",
            "stroke-opacity": "1",
            "fill": "none",
            "fill-opacity": "1",
            "label": true,
            "label-position": "nw",
            "color": "#a4a4a4"
        "nodes": [
            "1e1d90a44661c2dc",
            "857b75b2703a5547",
            "10ed98f8720adaca",
            "9a8b01ac9b9d5bc8",
            "861d4a82fc7471d2",
            "47b6ba00be43e308",
            "bd7aaa5dbe362511",
            "55ebd375010e5ca5",
            "4f57f015d2716d39",
            "9a35189ec430d633",
            "22747245529fa398",
            "72e52041865e0fec",
            "cd4c0b0979d81a43",
            "b98476be7ea0f58e",
            "68032d67d0654b4f",
            "c25362bbc892d289"
        "x": 74,
        "y": 359,
        "w": 812,
        "h": 502
        "id": "1e1d90a44661c2dc",
        "g": "5be4c59e7ae77b49",
        "x": 460,
        "y": 520,
                "861d4a82fc7471d2",
                "72e52041865e0fec",
                "857b75b2703a5547"
        "id": "857b75b2703a5547",
        "CN": "test_est_002",
        "C": "DE",
        "L": "",
        "ST": "",
        "postalCode": "",
        "streetAdress": "",
        "serialNumber": "",
        "emailAdress": "",
        "givenName": "",
        "surName": "",
        "initials": "",
        "title": "",
        "description": "",
        "ipAddress1": "",
        "ipAddress2": "",
        "ipAddress3": "",
        "Uri1": "",
        "Uri2": "",
        "Uri3": "",
        "Dns1": "",
        "Dns2": "",
        "Dns3": "",
        "x": 460,
        "y": 580,
                "47b6ba00be43e308",
                "22747245529fa398"
        "id": "10ed98f8720adaca",
        "client_type": "EST",
        "x": 460,
        "y": 700,
                "55ebd375010e5ca5",
                "9a8b01ac9b9d5bc8"
        "id": "9a8b01ac9b9d5bc8",
        "fileName": "x509_cert_est_1",
        "x": 460,
        "y": 760,
                "4f57f015d2716d39"
        "id": "861d4a82fc7471d2",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 700,
        "y": 480,
        "id": "47b6ba00be43e308",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 720,
        "y": 580,
        "id": "bd7aaa5dbe362511",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 690,
        "y": 640,
        "id": "55ebd375010e5ca5",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 710,
        "y": 700,
        "id": "4f57f015d2716d39",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 700,
        "y": 760,
        "id": "9a35189ec430d633",
        "type": "inject",
        "name": "trigger",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 190,
        "y": 520,
                "1e1d90a44661c2dc"
        "id": "22747245529fa398",
        "x": 450,
        "y": 640,
                "10ed98f8720adaca",
                "bd7aaa5dbe362511"
        "id": "72e52041865e0fec",
        "x": 690,
        "y": 520,
        "id": "cd4c0b0979d81a43",
        "fileName": "testcert_est_01",
        "fileExtension": "cer",
        "x": 460,
        "y": 820,
                "b98476be7ea0f58e"
        "id": "b98476be7ea0f58e",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 690,
        "y": 820,
        "id": "68032d67d0654b4f",
        "type": "comment",
        "name": "EST PKCS10 enrollment",
        "info": "",
        "x": 210,
        "y": 400,
        "id": "c25362bbc892d289",
        "type": "comment",
        "info": "",
        "x": 340,
        "y": 440,
        "cert": "",
        "key": "",
        "ca": "",
        "servername": "",
        "alpnprotocol": ""
Example 3: Certificate Revocation Status
Revocation status
        "id": "4c882a8e897f4a62",
        "type": "revocation-status",
        "serialNumber_fieldType": "str",
        "serialNumber": "6BC04C40DD3E4B7F90340CC8B6F4660FCE931939",
        "x": 470,
        "y": 160,
                "160147056b61e853"
        "id": "5e198606b2b6739d",
        "type": "inject",
        "name": "trigger",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 190,
        "y": 160,
                "4c882a8e897f4a62"
        "id": "160147056b61e853",
        "type": "debug",
        "name": "debug revocation status",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 710,
        "y": 160,
        "cert": "",
        "key": "",
        "ca": "",
        "servername": "",
        "alpnprotocol": ""
        "ejbcaConf": "{\n    \"subjects\": [\n        {\n            \"property\": \"CN\",\n            \"prop_value\": \"\",\n            \"prop_required\": true,\n            \"prop_modifiable\": true\n        },\n        {\n            \"property\": \"O\",\n            \"prop_value\": \"Campus Schwarzwald\",\n            \"prop_required\": true,\n            \"prop_modifiable\": false\n        },\n        {\n            \"property\": \"OU\",\n            \"prop_value\": \"Showcase Robot\",\n            \"prop_required\": true,\n            \"prop_modifiable\": false\n        },\n        {\n            \"property\": \"C\",\n            \"prop_value\": \"DE\",\n            \"prop_required\": true,\n            \"prop_modifiable\": false\n        }\n    ],\n    \"subject_alternative_names\": [],\n    \"profile\": {\n        \"hostname\": \"campuspki.germanywestcentral.cloudapp.azure.com\",\n        \"certificate_profile_name\": \"KF-CS-ShowcaseRobot-MQTT-CertProfile\",\n        \"end_entity_profile_name\": \"KF-CS-ShowcaseRobot-MQTT-Client-EndEntity\",\n        \"certificate_authority_name\": \"KS-CS-ShowcaseRobot-MQTT-CA\",\n        \"username\": {\n            \"value\": \"\",\n            \"auto_generated\": false\n        },\n        \"enrollment_code\": {\n            \"required\": true,\n            \"auto_generated\": false,\n            \"minimum_bits\": 0\n        },\n        \"mail\": {\n            \"use\": true,\n            \"required\": false,\n            \"modifiable\": false\n        }\n    }\n}"
Example 4: EJBCA Status Check
EJBCA status
        "id": "aa2a9a549ee0b813",
        "type": "ejbca-status",
        "x": 450,
        "y": 80,
                "aff9a51a7c018eef"
        "id": "aff9a51a7c018eef",
        "type": "debug",
        "name": "debug EJBCA status",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 700,
        "y": 80,
        "id": "a65c6140332d3fa3",
        "type": "inject",
        "name": "trigger",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 190,
        "y": 80,
                "aa2a9a549ee0b813"
        "cert": "",
        "key": "",
        "ca": "",
        "servername": "",
        "alpnprotocol": ""
Contributing
Contributions are welcome! If you would like to contribute to this project or report issues, please follow our Contributing Guidelines.
This Node-RED EJBCA Integration Package is licensed under the MIT License.
Authors
FHatCSW - GitHub Profile
Version: 1.0.15
Updated 3 years, 1 month ago
  • ejbca-status
  • export-keys
  • create-csr
  • ejbca-config-3
  • configure-entity
  • enroll-pkcs10
  • generate-p12
  • revocation-status
  • revoke
  • enroll-keystore
  • store-certificate
