node-red-contrib-effekttariff 0.2.7
Node-RED node for capacity tariff peak shaving — Swedish effekttariff and Belgian capaciteitstarief
npm install node-red-contrib-effekttariff
Node-RED node for capacity tariff peak shaving. Supports both Swedish "effekttariff" and the Flemish (Belgium) "capaciteitstarief".
Supported Regions
This node supports two capacity tariff models:
  • Sweden (Effekttariff): Hourly measurement, 2-3 highest peaks per month, seasonal (Nov-Mar)
  • Flanders, Belgium (Capaciteitstarief): 15-minute measurement, single highest peak per month, 12-month rolling average
Understanding Capacity Tariffs
In Sweden, your total electricity cost is typically composed of two main parts:
  1. Energy Cost (Spot Price): The price for the actual electricity (kWh) you consume. With a dynamic contract ("rörligt elpris med timprisavtal"), this price changes every hour based on the Nord Pool spot market.
  2. Grid Fee (Nätavgift): What you pay to your local grid company (nätbolag) for grid maintenance and usage.
The Swedish power tariff (effektavgift) is based on the average of your 2-3 highest hourly consumption values during a month. These peaks are often only measured on different weekdays during specific "peak hours" (e.g., 07:00-21:00) and during winter months (November-March).
Starting January 2023, households in Flanders (Belgium) have a capacity tariff based on:
  • 15-minute measurement intervals using fixed blocks aligned to clock boundaries (0:00, 0:15, 0:30, 0:45) — not a rolling window
  • Single highest peak per month determines monthly capacity
  • 12-month rolling average for annual billing
  • 24/7 measurement (no peak hours, no seasonal restrictions)
  • Cost: ~€50/kW/year based on the rolling average
A single high-power event (like EV charging at 11kW) can significantly impact your annual capacity fee, making peak shaving especially valuable for households in Flanders.
How the Power Tariff Works
The goal of the power tariff is to encourage users to spread out their consumption and reduce load on the grid. It does this by adding a fee based on your highest consumption peaks.
Important: You must configure this node according to your specific grid company's rules, or use the region presets for quick setup.
Disclaimer: The peak reduction estimates provided by this node and its tools are theoretical. Actual savings depend on many factors including your consumption patterns, equipment response times, battery efficiency, and grid conditions. Results may vary from simulated values.
Then restart Node-RED.
effekttariff
The main peak-shaving node. Tracks consumption peaks and outputs an AC input current limit to keep your monthly capacity fee in check. Supports Swedish effekttariff and Flemish capaciteitstarief billing models.
effekttariff-p1
Adapter for smart meters that expose OBIS 1-0:1.4.0 (quarter-hour demand) and 1-0:1.6.0 (monthly peak) on their P1 port — currently Fluvius digital meters in Flanders. Normalises the meter data to Watts and outputs it in the format effekttariff expects, so the node tracks the exact billing value rather than computing its own accumulation.
Wire it as: P1 source (MQTT / ESPHome) → effekttariff-p1 → effekttariff (Belgium preset)
Example flow showing the Effekttariff node connected to Victron Energy components
Example integration with Victron Energy: grid meter power feeds into the node; outputs drive the inverter current limit, Venus OS grid set-point, battery charge rate, and a Dashboard 2.0 chart.
Input
Connect a Grid Meter node (Power in Watts) to the input. The node expects positive values for grid import.
Outputs
  1. Current Limit (A): Target current limit in Amperes. Connect to your ESS current limit control (e.g., Victron Ac/In/1/CurrentLimit). Only outputs when the value changes.
  2. Status: Object with detailed peak data for debugging or dashboard display.
  3. Charge Rate (W): Battery charge rate recommendation in Watts (only when battery charging is enabled). Connect to your battery charge controller to ensure the battery is charged before peak hours.
  4. Chart Data: Array of chart-ready messages for Dashboard 1.0 and FlowFuse Dashboard 2.0. Connect to a ui-chart node to visualize consumption, limits, and peaks in real-time. Each message has a topic (series name) and a numeric payload (value in Watts or %). Series include: consumption, limit, target, peak_avg, battery_soc.
Region Preset
Use the region preset dropdown for quick configuration:
Region Description
Custom Manual configuration of all settings
Sweden 60-min intervals, 3 peaks/month, one per day, peak hours 07-21, season Nov-Mar
Belgium 15-min intervals, single peak/month, 24/7 measurement, 12-month rolling average
Measurement Settings (Belgium/Advanced)
Setting Description Default
Measurement interval 15, 30, or 60 minutes 60 min
Single peak per month Only track highest peak per month (Belgium-style) No
Annual billing Enable 12-month rolling average (Belgium-style) No
Rolling months Number of months to average for annual billing 12
Peak Measurement (Sweden)
Peaks to average Number of top peaks used for monthly average 3
One peak per day Only count the highest peak each day Yes
Peak hours Time window for measurement (e.g., 07:00-21:00) 07-21
Weekdays only Skip weekends No
Night discount 50% Consumption 22:00-06:00 counts at 50% No
Winter season only Only measure during specified months Yes
Season Month range (e.g., November-March) Nov-Mar
Limits
Minimum (kW) Floor value, never go below this 4 kW
Headroom (kW) Buffer below target for reaction time 0.3 kW
Electrical
Phases 1 or 3 phase installation 3
Grid voltage Your grid voltage 230 V
Max breaker Safety cap, never exceed this 25 A
Threshold-based limiting Only apply current limit when the running average of the current interval reaches the peak threshold. Recommended for three-phase systems with unbalanced loads (capaciteitstarief). No
Battery Charging (Optional)
Enable smart battery charging to ensure your battery is charged before peak hours. This allows effective peak shaving by having enough stored energy ready.
Enable battery charging Activate battery charge control No
SOC context key Global context key for current SOC (%) battery.soc
Min SOC context key Global context key for minimum SOC (%) battery.minSoc
Capacity (kWh) Battery capacity in kWh 10 kWh
Max charge rate (W) Maximum charge rate in Watts 3000 W
SOC buffer (%) Target SOC = minSoc + buffer 20%
How it works:
  • During off-peak hours, the node calculates how much time remains until peak hours
  • It determines the energy needed to reach target SOC (minSoc + buffer)
  • Outputs a charge rate that ensures the battery is ready before peaks
  • During peak hours, charge rate is 0 (battery should be available for discharge)
Integration:
  1. Set up a battery monitoring node to store SOC in global context
  2. Configure the context keys to match your setup
  3. Connect the third output (Charge Rate) to your battery charge controller
Status Indicator
  • Grey ring: Off-season
  • Green ring: Off-peak hours
  • Blue ring: Learning phase (tracking but using minimum limit)
  • Blue dot: Peak hours, usage well below target
  • Yellow dot: Peak hours, approaching target (>85%)
  • Red dot: Peak hours, over target (>105%)
Learning Phase
At the start of each month (or first use), the node enters a learning phase until it has recorded enough peaks. During learning, it outputs the minimum limit to prevent establishing unnecessarily high peaks.
Watts to Amps Conversion
  • 1-phase: Amps = Watts / Voltage
  • 3-phase: Amps = Watts / (3 × Voltage)
Example at 230V: 4 kW = 17.4A (1-phase) or 5.8A (3-phase)
Provider Examples
Sweden
Provider Peaks Hours Season Night Weekdays
Ellevio 3 07-19 Nov-Mar No Yes
Kungälv Energi 3 07-21 Nov-Mar Yes Yes
Jönköping Energi 2 07-21 All year No No
Belgium (Flanders)
Setting Value
Measurement interval 15 minutes
Peak tracking Single highest per month
Billing period 12-month rolling average
Peak hours 24/7 (no restrictions)
Season All year
Quick Setup: Select "Belgium" from the Region dropdown to auto-configure all settings.
Future Development
This node is under active development. Future enhancements will focus on creating a more comprehensive "Cost-Saving Optimizer" by integrating dynamic spot prices.
  • Flexible Tariff Models: Allow users to select their grid company's specific power tariff model (average of N peaks vs. single highest peak).
  • Cost-Aware Logic: Make the battery charging and discharging logic aware of the hourly energy price. The system will then be able to make economic decisions, balancing the cost of the power tariff against the cost of the energy itself.
Battery Sizing Tool
An interactive web-based tool is available to help you understand how a battery can reduce your effekttariff peaks. The tool simulates different battery configurations and consumption profiles to estimate potential savings.
Try the Battery Sizing Tool (English/Swedish)
Features:
  • Adjust battery capacity, charge rates, and SOC settings
  • Choose from predefined consumption profiles (typical household, EV charging, heat pump)
  • Configure your grid provider's peak hours and peak count
  • Set your electrical installation (phases, breaker size)
  • View simulated peak reduction with interactive charts
Note: The simulation results are theoretical estimates based on simplified consumption patterns. Actual savings depend on your real consumption behavior, battery efficiency, grid conditions, and other factors. Use the tool for guidance and planning purposes only.
Simulation & Testing
The package includes a simulation framework for testing and validating system behavior without connecting to real hardware.
Running Simulations
# List all available scenarios
npm run simulate
# Run a specific scenario
npm run simulate:scenario basicWeek
# Run all scenarios
npm run simulate:all
# Run with verbose output
npm run simulate:verbose basicWeek
# Generate HTML report with interactive charts
node scripts/run-simulation.js basicWeek --html
# Export data to CSV files
node scripts/run-simulation.js basicWeek --csv
# Generate both HTML and CSV
node scripts/run-simulation.js basicWeek --html --csv
Visualization Options
The simulation CLI supports two visualization modes:
HTML Report (--html): Generates an interactive HTML report with Chart.js charts showing:
  • Hourly power consumption vs limit (line chart)
  • Top recorded peaks (horizontal bar chart)
  • Battery SOC over time (if applicable)
  • Battery charge rate (if applicable)
The HTML file auto-opens in your default browser.
CSV Export (--csv): Exports simulation data to CSV files:
  • *_hourly.csv - Hourly consumption data
  • *_peaks.csv - Peak records with timestamps
  • *_limits.csv - Limit changes over time
  • *_battery.csv - Battery data (if applicable)
Output files are saved to ./simulation-output/.
Available Scenarios
Interactive HTML reports are automatically generated and available online. View all simulation reports
Scenario Description Duration Report
basicWeek Typical Swedish household consumption 7 days View
fullMonth Complete month to verify peak reset 35 days View
highSpikes Baseline with EV charging/sauna spikes 14 days View
nightDiscount Tests night discount (nattsänkning) feature 7 days View
weekdaysOnly Weekday-only limit enforcement (Ellevio style) 14 days View
winterSeason Winter season filtering (Nov-Mar) 60 days View
singlePhase Single phase installation 7 days View
minimumLimit Very low consumption, minimum limit test 7 days View
jonkoping Jönköping Energi configuration (2 peaks) 14 days View
stressTest High variability consumption 30 days View
batteryCharging Smart battery charging during off-peak 7 days View
batteryBalancing Periodic battery balancing feature 1 day View
dynamicHeadroom Dynamic headroom based on battery SOC 1 day View
downtimeDetection System downtime detection with data gaps 3 days View
belgiumBasic Belgian capacity tariff with 15-min intervals 30 days View
belgiumWithEV Belgian household with 11kW EV charging 30 days View
belgiumAnnualRolling Full year showing 12-month rolling average 395 days View
belgiumThreephase Three-phase unbalanced loads with threshold limiting 30 days View
Running Tests
# Run all tests
npm test
# Run with coverage
npm run test:coverage
# Run in watch mode during development
npm run test:watch
MIT
Author
Dirk-Jan Faber test
Version: 0.2.7
Updated 6 months ago
13 in the last week
  • effekttariff
  • effekttariff-p1
  • victron
  • effekttariff
  • capaciteitstarief
  • capacity-tariff
  • peak-shaving
  • sweden
  • belgium
  • flanders
  • vlaanderen
  • energy
