node-red-contrib-edgeberry-hub 0.1.0
Node-RED nodes for Edgeberry Device Hub integration
npm install node-red-contrib-edgeberry-hub
Node-RED nodes for Edgeberry Device Hub integration.
Install via npm:
Or install directly from the Node-RED palette manager:
  1. Open Node-RED
  2. Go to Menu → Manage palette
  3. Search for node-red-contrib-edgeberry-hub
  4. Click Install
Edgeberry Device
The Edgeberry Device node provides integration with Edgeberry Device Hub instances.
The node requires the following configuration:
  • Name (optional): A descriptive name for this node instance
  • Host (required): The Device Hub endpoint URL (e.g., https://devicehub.local or https://devicehub.example.com)
  • Device ID (required): The identifier of the device this node represents (e.g., device-001)
  • Host Access Token (required): Authentication token for Device Hub API access (stored as credential)
Note: Access token functionality is not yet implemented in the current version.
  1. Drag the Edgeberry Device node from the Edgeberry Hub category in the palette
  2. Double-click to configure the required fields
  3. Connect input and output as needed in your flow
  4. Deploy the flow
Current Behavior
  • Logs "hello world" message when receiving input
  • Passes input messages through unchanged
  • Validates configuration on startup
License & Collaboration
Copyright 2025 Sanne 'SpuQ' Santens. The Edgeberry Device Hub project is licensed under the GNU GPLv3. The Rules & Guidelines apply to the usage of the Edgeberry brand.
Collaboration
If you'd like to contribute to this project, please follow these guidelines:
  1. Fork the repository and create your branch from main.
  2. Make your changes and ensure they adhere to the project's coding style and conventions.
  3. Test your changes thoroughly.
  4. Ensure your commits are descriptive and well-documented.
  5. Open a pull request, describing the changes you've made and the problem or feature they address.
Version: 0.1.0
Updated 11 months ago
License: GPL-3.0-or-later
  • edgeberry-device
  • edgeberry
  • device-hub
  • iot
  • node-red-contrib
