node-red-contrib-edgeberry 0.1.16
Node-RED node to interact with the Edgeberry Device Software over DBus
npm install node-red-contrib-edgeberry
Edgeberry Banner
NodeRED is a visual programming tool that lets you wire together hardware, APIs, and online services by connecting blocks in a flow-based editor. The Edgeberry NodeRED node lets your Node-RED flows communicate with the Edgeberry Device Software over DBus.
Install in Node-RED UI
ToDo
Manual install
On your device, navigate to the nodered folder, and run
License & Collaboration
Copyright© 2025 Sanne 'SpuQ' Santens. The Edgeberry NodeRED node is licensed under the MIT License. The Rules & Guidelines apply to the usage of the Edgeberry™ brand.
Collaboration
If you'd like to contribute to this project, please follow these guidelines:
  1. Fork the repository and create your branch from main.
  2. Make your changes and ensure they adhere to the project's coding style and conventions.
  3. Test your changes thoroughly.
  4. Ensure your commits are descriptive and well-documented.
  5. Open a pull request, describing the changes you've made and the problem or feature they address.
Version: 0.1.16
Updated 1 year ago
  • edgeberry
  • node-red-node
  • edgeberry
