node-red-contrib-edge-tts 3.0.4
An simple Azure Speech Service module that uses the Microsoft Edge Read Aloud API.
npm install node-red-contrib-edge-tts
A Node-RED node that converts text to speech using Microsoft Edge's Text-to-Speech service. This node provides a simple way to integrate Azure Speech Service capabilities into your Node-RED flows without requiring an Azure account or API key.
Overview
This node uses the Microsoft Edge Read Aloud API to generate high-quality speech from text. It supports a wide range of voices across multiple languages and dialects, with customizable speech parameters such as rate, pitch, and volume.
Changlog
2025-04-25 :
  • Update version 3. x
  • Not compatible with version 2. x
  • Add voice character
  • Add new agent
  • Other modifications
  • No Azure account or API key required
  • 100+ neural voices across multiple languages
  • Adjustable speech parameters (rate, pitch, volume)
  • Multiple output formats
  • Support for SOCKS proxy
  • Word and sentence boundary markers (optional)
Install via Node-RED's Manage Palette:
Or install via npm:
Requirements
  • Node.js >= 16.0.0
  • Node-RED >= 3.0.0
  1. Drag the "MS Edge TTS" node from the TTS category in the palette to your flow
  2. Configure the node with your desired voice and other parameters
  3. Send a message with text to convert to speech
  4. example:
        "id": "78d47d120957febb",
        "type": "edge-tts",
        "z": "f0c558c25f0f876f",
        "name": "EDGE-TTS",
        "voice": "en-US-AriaNeural",
        "text": "Hello World",
        "filename": "tts.mp3",
        "rate": "0",
        "pitch": "0",
        "volume": "100",
        "format": "audio-24khz-48kbitrate-mono-mp3",
        "voiceLocale": "",
        "sentenceBoundary": "",
        "wordBoundary": "",
        "x": 590,
        "y": 280,
                "a18e1cce694f3a0b"
        "id": "07440fc59373f654",
        "type": "inject",
        "name": "basic text to speech",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 370,
        "y": 280,
                "78d47d120957febb"
        "id": "a18e1cce694f3a0b",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 800,
        "y": 280,
        "id": "e562d5502180b41a",
        "type": "edge-tts",
        "name": "EDGE-TTS",
        "text": "",
        "filename": "",
        "rate": "0",
        "pitch": "0",
        "volume": "100",
        "voiceLocale": "",
        "wordBoundary": "",
        "x": 590,
        "y": 420,
                "390baf4035c6e2c2"
        "id": "6ab5012df8d88444",
        "type": "inject",
        "name": "Advanced Usage",
        "props": [
                "p": "text",
                "v": "Bonjour à tous dans le monde !",
                "vt": "str"
                "p": "voice",
                "v": "fr-FR-HenriNeural",
                "vt": "str"
                "p": "filename",
                "v": "/home/tts.webm",
                "vt": "str"
                "p": "format",
                "v": "webm-24khz-16bit-mono-opus",
                "vt": "str"
                "p": "pitch",
                "v": "10",
                "vt": "num"
                "p": "rate",
                "v": "15",
                "vt": "num"
                "p": "volume",
                "v": "50",
                "vt": "num"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 380,
        "y": 420,
                "e562d5502180b41a"
        "id": "390baf4035c6e2c2",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 800,
        "y": 420,
Input
The node accepts the following input properties:
  • msg.payload (string): Text to convert to speech (if msg.text is not provided)
  • msg.text (string): Text to convert to speech (takes precedence over payload)
  • msg.filename (string): Path to save the audio file (default: tts_[timestamp].mp3)
  • msg.voice (string): Voice to use for speech synthesis
  • msg.rate (number): Speech rate adjustment (-100 to 100)
  • msg.pitch (number): Speech pitch adjustment in Hz
  • msg.volume (number): Speech volume (0-100)
  • msg.format (string): Audio output format
  • msg.agent (string): SOCKS proxy URL (if needed)
  • msg.voiceLocale (string): Voice locale
  • msg.sentenceBoundary (boolean): Enable sentence boundary markers
  • msg.wordBoundary (boolean): Enable word boundary markers
Output
The node outputs a message with the following properties:
  • msg.result: Buffer containing the audio data
  • msg.filename: Path to the saved audio file
Basic Settings
  • Name: Custom name for the node (optional)
  • Voice: Select from 100+ available neural voices
  • Text: Default text to convert (can be overridden by input message)
  • Filename: Default path to save the audio file
Advanced Settings
  • Rate: Speech rate adjustment (-100 to 100)
  • Pitch: Speech pitch adjustment in Hz
  • Volume: Speech volume (0-100)
  • Format: Audio output format (default: audio-24khz-48kbitrate-mono-mp3)
  • Voice Locale: Voice locale setting
  • Sentence Boundary: Enable sentence boundary markers
  • Word Boundary: Enable word boundary markers
  • Proxy Agent: SOCKS proxy URL (if needed)
Example Flow
A simple example flow is included in the examples directory.
Supported Voices
The node supports a wide range of voices across multiple languages and dialects, including:
  • English (US, UK, Australia, etc.)
  • Chinese (Mandarin, Cantonese, etc.)
  • And many more
Refer to the LICENSE file in the repository.
Credits
This node is based on the msedge-tts package.
Issues and Contributions
Please report any issues or feature requests on the GitHub repository.
Version: 3.0.4
Updated 1 year, 7 months ago
Rating: 4.4 7
27 in the last week
  • edge-tts
  • edge
  • tts
  • readaloud
