node-red-contrib-easye4-mqtt 4.1.5
Node-RED nodes for the Eaton easyE4 via its MQTT interface: read/write operands, RUN/STOP, function blocks, program and firmware updates (English/Deutsch)
npm install node-red-contrib-easye4-mqtt
English | Deutsch | Disclaimer / Haftungsausschluss
Node-RED nodes for the Eaton easyE4 (firmware 2.40 or later) via its universal MQTT interface. Node-RED-Knoten für die Eaton easyE4 (Firmware ab 2.40) über die universelle MQTT-Anbindung.
English
The editor dialogs, help texts and messages are available in English and German. Node-RED chooses the language automatically (browser language or User Settings → View → Language).
Node Purpose
easyE4 (config) Controller: MQTT broker + one base topic, once per controller
easyE4 read Read an operand (type + index, e.g. MW 3, or alias)
easyE4 write Write an operand
easyE4 action RUN/STOP, function blocks (type + index), program and firmware update
The nodes appear in their own palette category easyE4.
In Node-RED: Menu → Manage palette → Install, search for node-red-contrib-easye4-mqtt, click Install.
Or on the command line:
node-red-restart
An importable example is available under Menu → Import → Examples.
Setup
  1. In easySoft 8 configure the broker connection (MQTT broker access, steps 1–3) and assign the four topics.
  2. On the Cyclic data tab add the operands and mark them as writable if needed.
  3. On the MQTT settings tab enable only the actions you need.
  4. In Node-RED drag an easyE4 read node into the flow, click the pencil icon next to Controller, create the MQTT broker (server/port, TLS if required) and enter a base topic (e.g. easye4/1). The dialog shows a table of the four topics to enter in easySoft 8 (<base>/data, /set, /actions/request, /actions/response). Custom topic names are possible with Individual.
  5. Use QoS 0: the easyE4 does not accept write requests with QoS 1 (firmware 2.46).
  • easyE4 read: select the controller, the operand type (e.g. MW – Marker (word)) and the index. msg.payload is the value, msg.topic the operand name. All operands outputs everything as one object.
  • easyE4 write: select controller, operand type and index, send the value in msg.payload (number or true/false). With From the message: msg.topic = operand or msg.payload = { M5: 1, MW3: 42 }. Non-writable operands are not offered in the dialog (Q, QA) or only from the first free index (I17, IA5, ID26).
  • easyE4 action: select the action in the dialog (or use msg.action); for function blocks select type and index; send a message to the input. The response arrives at the output with msg.success, msg.errorMsg and msg.response.
Status
Below the nodes you can see whether the easyE4 is online: green (online or current value), red "easyE4 offline" or grey "device unknown". It is based on the connected message of the easyE4 (last will via the broker). After switching off the controller it takes up to 1.5 keep-alive periods (up to 90 s at 60 s) until "offline" appears. After a Node-RED restart the status stays grey until the easyE4 sends its next message.
TLS certificates (optional)
The package contains the script tools/easye4-zertifikate.sh (messages in German). On the Raspberry Pi it creates your own certificate authority (CA) and the server certificate for Mosquitto, within the limits of the easyE4 (CA file at most 1728 bytes, IP address as both IP and DNS entry). Replace 192.168.1.50 with the IP address of the Pi:
bash ~/.node-red/node_modules/node-red-contrib-easye4-mqtt/tools/easye4-zertifikate.sh 192.168.1.50 raspberrypi.local
The files are written to ~/mqtt-zertifikate: select ca.crt in easySoft 8 as Broker CA certificate and use it for Mosquitto (cafile); server.crt/server.key are for Mosquitto (certfile/keyfile). Keep ca.key and server.key secret. For mutual TLS, bash .../easye4-zertifikate.sh sign <file.csr> signs the CSR created in easySoft 8.
Notes
  • Operands are only sent in RUN mode.
  • Q, QA, I1–I16, IA1–IA4 and ID1–ID25 cannot be written via MQTT; the node rejects them.
  • M1 and M001 are treated as the same operand when reading.
  • Function block changes are temporary; use the action Save FB changes to make them permanent.
  • Commands are never sent with retain.
Upgrading from version 3
Existing flows keep working: old nodes with a text field "operand" and individually entered topics are converted to type + index or shown as Individual when the dialog is opened.
MIT – see LICENSE. Use at your own risk, no liability.
Bugs and questions
Please report problems at GitHub Issues.
Deutsch
Die Dialoge, Hilfetexte und Meldungen gibt es auf Deutsch und Englisch. Node-RED wählt die Sprache automatisch (Sprache des Browsers oder Benutzereinstellungen → Ansicht → Sprache).
Knoten Aufgabe
easyE4 (Konfiguration) Steuerung: MQTT-Broker + ein Basis-Topic, einmal pro Steuerung
easyE4 lesen Operand lesen (Typ + Index, z. B. MW 3, oder Alias)
easyE4 schreiben Operand schreiben
easyE4 aktion RUN/STOP, Funktionsbausteine (Typ + Index), Programm- und Firmware-Update
Die Knoten erscheinen in der Palette in der eigenen Kategorie easyE4.
In Node-RED: Menü → Palette verwalten → Installation, nach node-red-contrib-easye4-mqtt suchen, Installieren klicken.
Oder in der Kommandozeile:
node-red-restart
Ein importierbares Beispiel liegt unter Menü → Import → Beispiele.
Einrichtung
  1. In easySoft 8 die Broker-Verbindung konfigurieren (MQTT Broker-Zugang, Schritt 1–3) und die vier Topics vergeben.
  2. Im Register Zyklische Daten die Operanden anlegen und ggf. als beschreibbar markieren.
  3. Im Register MQTT Einstellungen nur die Aktionen freigeben, die benötigt werden.
  4. In Node-RED einen Knoten easyE4 lesen ziehen, bei Steuerung das Stift-Symbol drücken, den MQTT-Broker anlegen (Server/Port, ggf. TLS) und ein Basis-Topic eintragen (z. B. easye4/1). Der Dialog zeigt als Tabelle, welche vier Topics in easySoft 8 einzutragen sind (<Basis>/data, /set, /actions/request, /actions/response). Eigene Topic-Namen sind über Einzeln möglich.
  5. QoS 0 verwenden: Die easyE4 übernimmt Schreibzugriffe mit QoS 1 nicht (Firmware 2.46).
Benutzung
  • easyE4 lesen: Steuerung wählen, Operandentyp (z. B. MW – Merker (Wort)) und Index wählen, fertig. msg.payload ist der Wert, msg.topic der Operandenname. Alle Operanden gibt alles als Objekt aus.
  • easyE4 schreiben: Steuerung, Operandentyp und Index wählen, Wert per msg.payload senden (Zahl oder true/false). Bei Aus der Nachricht: msg.topic = Operand oder msg.payload = { M5: 1, MW3: 42 }. Nicht beschreibbare Operanden gibt es im Dialog nicht (Q, QA) bzw. erst ab dem ersten freien Index (I17, IA5, ID26).
  • easyE4 aktion: Aktion im Dialog wählen (oder msg.action), bei Funktionsbausteinen Typ und Index wählen, Nachricht an den Eingang senden. Die Antwort kommt am Ausgang mit msg.success, msg.errorMsg und msg.response.
Statusanzeige
Unter den Knoten steht, ob die easyE4 online ist: grün (online bzw. aktueller Wert), rot "easyE4 offline" oder grau "Gerät unbekannt". Grundlage ist die connected-Meldung der easyE4 (Letzter Wille des Brokers). Nach dem Ausschalten der Steuerung dauert es bis zu 1,5 Keep-Alive-Zeiten (bei 60 s bis zu 90 s), bis "offline" erscheint. Nach einem Neustart von Node-RED bleibt die Anzeige grau, bis die easyE4 die nächste Meldung sendet.
Zertifikate für TLS (optional)
Im Paket liegt das Skript tools/easye4-zertifikate.sh. Es erzeugt auf dem Raspberry Pi eine eigene Zertifizierungsstelle (CA) und das Serverzertifikat für Mosquitto, passend zu den Grenzen der easyE4 (CA-Datei höchstens 1728 Bytes, IP-Adresse als IP- und Namenseintrag). Statt 192.168.1.50 die IP-Adresse des Pi eintragen:
Die Dateien landen in ~/mqtt-zertifikate: ca.crt in easySoft 8 als Broker CA Zertifikat wählen und für Mosquitto verwenden (cafile), server.crt/server.key für Mosquitto (certfile/keyfile). ca.key und server.key geheim halten. Für Mutual TLS signiert bash .../easye4-zertifikate.sh sign <datei.csr> die in easySoft 8 erzeugte CSR-Datei.
Hinweise
  • Operanden werden nur im Zustand RUN gesendet.
  • Q, QA, I1–I16, IA1–IA4 und ID1–ID25 sind über MQTT nicht beschreibbar; der Knoten lehnt sie ab.
  • M1 und M001 gelten beim Lesen als derselbe Operand.
  • Funktionsbaustein-Änderungen wirken nur temporär; mit der Aktion FB-Änderungen speichern werden sie dauerhaft.
  • Befehle werden nie mit Retain gesendet.
Update von Version 3
Bestehende Flows laufen weiter: alte Knoten mit Textfeld "Operand" und einzeln eingetragenen Topics werden beim Öffnen des Dialogs automatisch in Typ + Index umgesetzt bzw. als Einzeln angezeigt.
Lizenz
MIT – siehe LICENSE. Benutzung auf eigene Gefahr, keinerlei Haftung.
Fehler und Fragen
Probleme bitte unter GitHub Issues melden.
This software controls real machines (writing operands, RUN/STOP, program and firmware updates). It is provided "as is" under the MIT license, without any warranty and without any liability for damage to persons, machines, installations or data. Never let safety functions depend on it. Unofficial project, not affiliated with or endorsed by Eaton.
Diese Software steuert reale Maschinen (Operanden schreiben, RUN/STOP, Programm- und Firmware-Updates). Sie wird unter der MIT-Lizenz „wie besehen“ bereitgestellt, ohne Gewährleistung und ohne jegliche Haftung für Schäden an Personen, Maschinen, Anlagen oder Daten. Sicherheitsfunktionen dürfen nie davon abhängen. Inoffizielles Projekt, nicht von Eaton.
Version: 4.1.5
Updated 3 days ago
Rating: 0.0
18 in the last week
  • easye4-device
  • easye4-in
  • easye4-out
  • easye4-action
  • mqtt
  • eaton
  • easye4
  • easy
  • plc
  • sps
  • steuerung
