node-red-contrib-easybotics-led-matrix 1.4.0
control led matrix with node-red on a raspberryPI, node-red binding of: https://www.npmjs.com/package/easybotics-rpi-rgb-led-matrix
npm install node-red-contrib-easybotics-led-matrix
set of node-red nodes binding to node-rpi-rgb-led-matrix library Node Red binding of: https://github.com/easybotics/node-rpi-rgb-led-matrix/
In Order for the HZELLER back end to function, node-red must be running as root! see here for a tutorial -> https://t3alliance.org/node-red-root/
You can configure the node-red service on rpi to run as root, with the pi users home-dir
Otherwise you may be confused when the roots client doesn't have any of your nodes or flows
You can also set this through the roots settings.json
Example Flow
Example Output
Version: 1.4.0
Updated 7 years, 3 months ago
License: GPL2
Rating: 4.0 3
53 in the last week
  • led-matrix
  • refresh-matrix
  • image-to-matrix
  • text-to-matrix
  • pixel-transform
  • circle
  • polygon
  • graph-to-matrix
  • raspberry
  • raspberrypi
  • pi
  • rpi
  • ledmatrix
  • led
  • matrix
  • hzeller
  • easybotics
