node-red-contrib-easy-pid-controller 2.0.1
A Node-RED node for implementing an easy PID controller
npm install node-red-contrib-easy-pid-controller
Easy PID Controller Node for Node-RED
The easy-pid-controller is a Node-RED node that provides industrial-grade Proportional-Integral-Derivative (PID) control based on simple-pid-controller v2.0.0. It integrates easily with PLCs, MQTT, and SCADA systems, and supports 0-10V and 4-20mA control signals with safety features like anti-windup, output clamping, and bumpless transfer.
  • Easy to configure PID parameters: Kp, Ki, Kd.
  • Setpoint (SV) and Process Variable (PV) inputs over msg.topic.
  • Outputs full PID status: PV, SV, error, P, I, D, output, scaled Signal, and Value.
  • Choice of control signal types: 0-10V or 4-20mA.
  • Anti-windup (integral clamping) and output clamping (min/max).
  • Deadband support to suppress output when the error is negligible.
  • settled handling: stop the loop automatically when within tolerance.
  • Manual / Auto mode with bumpless transfer.
  • Runtime gain tuning (gains topic) and controller reset (reset topic).
  • Real-time status updates via node status text and optional MQTT/InfluxDB integration.
  1. Drag and drop the easy-pid-controller node into your Node-RED flow.
  2. Double click on the node to configure:
    • PID gains: Kp, Ki, Kd.
    • Loop interval dt (seconds).
    • Output and integral limits.
    • Deadband and settled tolerance.
    • Signal type (0-10V or 4-20mA) and engineering range.
  3. Connect MQTT / Inject / Function nodes to provide SV, PV, auto, and optional advanced topics (gains, mode, manual_output, reset).
  4. Deploy and monitor the outputs (output, Signal, Value, mode) in real-time.
Inputs
All control is driven by msg.topic and msg.payload:
  • SV (number)
    Desired setpoint value for the controller.
    • msg.topic = "SV"
    • msg.payload = <number>
  • PV (number)
    Process variable / current state of the system.
    • msg.topic = "PV"
  • auto (boolean)
    Start/stop the PID loop and auto mode.
    • msg.topic = "auto"
    • msg.payload = true → start loop and switch to auto mode
    • msg.payload = false → stop loop and switch to manual mode
  • gains (object) — v2.0.0
    Runtime PID gain tuning without restarting the node.
    • msg.topic = "gains"
    • msg.payload = { k_p: <number>, k_i: <number>, k_d: <number> }
  • mode (string) — v2.0.0
    Explicitly switch controller mode.
    • msg.topic = "mode"
    • msg.payload = "auto" or "manual"
    • Switching manual → auto uses bumpless transfer (no output jump).
  • manual_output (number) — v2.0.0
    Fixed output used in manual mode, also seeds bumpless transfer when returning to auto.
    • msg.topic = "manual_output"
  • reset (any) — v2.0.0
    Reset controller internal state (integral, derivative, timestamp).
    • msg.topic = "reset"
    • msg.payload can be any value
Outputs
The node outputs an object on msg.payload with the following fields (from simple-pid-controller v2.0.0):
  • PV (number)
    Current process variable.
  • SV (number)
    Current setpoint.
  • error (number) — v2.0.0
    Current control error: SV - PV.
  • P (number)
    Proportional component.
  • I (number)
    Integral component (clamped by Integral Min/Max for anti-windup).
  • D (number)
    Derivative component (derivative on measurement — no kick on setpoint changes).
  • output (number) — v2.0.0
    Raw clamped PID output (P + I + D, limited by Output Min/Max).
  • Signal (number)
    Output mapped to the configured signal range:
    • 0-10V → 0 to 10
    • 4-20mA → 4 to 20
  • Value (number)
    PV mapped to the signal units for easier UI or Range node usage.
    Current controller mode: "auto" or "manual".
Node Configuration Fields (Editor)
  • Kp, Ki, Kd: PID gains.
  • dt (s): Target loop interval in seconds (controller internally uses dynamic timestamps; dt is a base rate / initial fallback).
  • Output Min / Output Max: Clamp bounds for output.
  • Integral Min / Integral Max: Anti-windup clamps on the integral accumulator.
  • Deadband: If |error| is below this value, output is forced to 0 (disable with 0).
  • Settled Tolerance: When |error| falls below this value, the controller emits a settled event and the node stops the loop; restart with auto: true.
  • Signal Type: 0-10V or 4-20mA.
  • Range Min / Range Max: Engineering range for mapping PV and output to signal units.
Changelog
v2.0.1
  • Updated core to use simple-pid-controller v2.0.0 with:
    • Dynamic dt based on real timestamps (constructor dt used as fallback).
    • Anti-windup via configurable Integral Min/Max.
    • Output clamping via Output Min/Max.
    • Deadband support to suppress small-error output.
    • setTarget() now resets integral and derivative state.
    • Derivative on measurement, avoiding derivative kick on setpoint steps.
    • EventEmitter-based update and settled events internally.
  • Inputs
    • Added: gains topic for runtime tuning of { k_p, k_i, k_d }.
    • Added: mode topic to switch auto/manual with bumpless transfer.
    • Added: manual_output topic to set fixed output in manual mode.
    • Added: reset topic to clear internal controller state.
    • Improved: auto topic now also sets mode to auto/manual instead of just starting/stopping the timer.
  • Outputs
    • Added: error, output, and mode in the payload.
    • Kept: PV, SV, P, I, D, Signal, Value for compatibility.
  • Node behaviour
    • Improved: Node status messages show setpoint, PV, mode, and reset events.
    • Improved: On node close, the controller is reset and the internal timer is cleared.
v1.2.1
  • Added: Node status updates during runtime to display relevant information like current PV, PID activation state, and more.
v1.2.0
  • Changed: Moved the Setpoint (SV) from node configuration to msg.payload with the topic SV.
v1.1.0
  • Added: New output value Value that provides the direct control signal based on the sensor type configuration.
  • Improved: Code documentation and error handling for invalid inputs.
v1.0.0
  • Initial release with basic PID functionalities.
  • Support for 0-10V and 4-20mA signal types.
Contributing
Contributions to improve the node or fix any issues are welcome. Please submit an issue or pull request on the GitHub repository.
GPL-3.0 License. See the LICENSE file for details.
Example
See the examples/ directory for sample flows illustrating:
  • Basic PID control.
  • MQTT-based SV/PV input.
  • InfluxDB logging of PID status.
  • Runtime gain tuning and mode switching.
Author
Harshad Joshi @ Bufferstack.IO Analytics Technology LLP, Pune
Version: 2.0.1
Updated 8 months, 1 week ago
License: GPL-3.0
Rating: 4.9 7
199 in the last week
  • easy-pid-controller
  • PID
  • controller
