node-red-contrib-dyson-purelink 0.8.6
NodeRed dyson purelink Adapter
npm install node-red-contrib-dyson-purelink
In need of maintainer
Since I stopped using Node-RED for my main home automation needs, I can no longer maintain this project. Please let me know if you want to take over this project. In the mean time I will try to fix bugs when they pop up. No guarantees that I will.
Node RED dyson pure link
This Node RED module can control dyson purifier. (tested with dyson hot&cool pure link)
Node-RED is a tool for wiring together hardware devices, APIs and online services in new and interesting ways.
:question: Get Help
I'm always open for bug reports and feature requests, please open issues.
:cloud: Installation
First of all install Node-RED
$ sudo npm install -g node-red
# Then open  the user data directory  `~/.node-red`  and install the package
$ cd ~/.node-red
$ npm install node-red-contrib-dyson-purelink
Or search for dyson-purelink in the manage palette menu
Then run
node-red
:yum: How to contribute
Have an idea? Found a bug? See how to contribute.
git clone https://codeberg.org/pbrunier/node-red-contrib-dyson-purelink.git
cd node-red-contrib-dyson-purelink
npm install
gulp
npm install /path/to/node-red-contrib-dyson-purelink
:memo: Documentation
Configuration:
  • E-Mail: dyson E-Mail
  • Password: dyson Password
  • Country: Country-Code (US,DE,AT,GB,...)
IMPORTANT: Deploy the node, before searching for devices.
node explanation:
INFO: IF you know the IP address of the device, it better to use this. Instead bonjour auto-discovery will be used. Sometimes this is magically not working correctly.
The action can be defined in the node properties or can be in the msg.payload.action.
Possible values are:
  • getTemperature
  • getAirQuality
  • getRelativeHumidity
  • getFanStatus
  • getFanSpeed
  • getTemperatureTarget
  • getJetFocus
  • getNightModeStatus
  • getRotationStatus
  • getAutoOnStatus
  • setRotation - rotation (true/false) {"action":"setRotation", "rotation": true}
  • setRotationAngle - min_angle (5-355 degrees), max_angle (5-355 degrees) {"action":"setRotationAngle", "min_angle": 90, "max_angle": 270}
  • setFanSpeed - speed in percent
    { "action": "setFanSpeed","speed": "100" }
  • setTemperatureTarget - Temperature target in degrees celcius (1-37 degrees) { "action": "setTemperatureTarget","temperatureTarget": "20" }
  • setJetFocusOn
  • setJetFocusOff
  • setNightModeOn
  • setNightModeOf
  • setHeatOn
  • setHeatOff
  • turnOn
  • turnOff
  • getDeviceInfo (for support)
For the following actions some additonal parameters are mandatory:
  • setRotation: msg.payload.rotation
  • setRotationAngle: msg.payload.min_angle, msg.payload.max_angle
  • setFanSpeed: msg.payload.speed
  • setTemperatureTarget: msg.payload.temperatureTarget
ExampleFlow:
Download and import to NodeRED - flow.json
:scroll: The MIT License
Version: 0.8.6
Updated 1 year, 11 months ago
Rating: 5.0 5
35 in the last week
  • dyson-config
  • dyson-link
  • dyson
  • purelink
  • Smart Home
  • home automation
  • Patrick Brunier
  • naimo84
  • ajago
