node-red-contrib-dyno-websocket 0.11.4
WebSocket with dynamic configuration that can be changed in runtime
npm install node-red-contrib-dyno-websocket
NPM Version
Dynamic WebSocket client node for Node-RED.
Source code is published at Codeberg
Node
  • Type: dyno-websocket
  • Inputs: 1
  • Outputs: 2 (data, control)
Configuration:
  • url: string, can be wss:// or ws:// schema
  • headers: object?: optional, http headers to send during upgrade
  • topic: string?: optional, given topic will be added to all outgoing msg
  • autoConnect: boolean?: when true, node attempts connection on deploy and relevant config updates
These are startup defaults and can be changed at runtime with commands.
Input Commands
Set msg.command to one of:
  • config-set: overwrite configuration of node. Configuration should be sent in msg.payload. If url or headers are sent while connected, connection will be re-opened with new settings. If disconnected and autoConnect is true, node will attempt to connect.
    • url: string
    • headers: object?
    • topic: string?
  • config-get: return current configuration in msg.payload
  • config-reset: reset dynamic configuration to values set in node editor
  • counters: return current runtime counters in msg.payload
  • counters-reset: reset runtime counters and return updated values in msg.payload
  • connect
  • disconnect
  • reconnect
If msg.command is not set, msg.payload is sent to the socket:
  • Buffer/Uint8Array: sent as binary frame
  • object: sent as JSON serialized string
  • others: sent as String(payload)
Outputs
Data output (output 1):
  • binary frame: raw Buffer
  • non-binary frame: parsed as JSON with fallback to plain-text
Control output (output 2):
  • Success:
    { topic?, event: string, ok: true, payload: any, counters: object }
  • Failure:
      topic?,
      event: string,
      ok: false,
      payload: { message: string, error: string, extra?: any },
      counters: object
Persistence
Node state is stored in node context (config, state) and can be inspected on Context Data page.
Note: settings will be lost after node re-deployment if Node-RED contextStorage is not set. Make sure you have at least one storage enabled, memory for example:
  // add to settings.js in you node-red home folder
  contextStorage: {
    default: { module: "memory" },
Version: 0.11.4
Updated 6 months, 3 weeks ago
4 in the last week
  • dyno-websocket
  • websocket
  • web-socket
  • dynamic
  • configuration
  • runtime
