node-red-contrib-dynamodb-variable 1.1.1
Node-RED node for storing and retrieving variables in AWS DynamoDB with flexible credential configuration
npm install node-red-contrib-dynamodb-variable
A Node-RED node for interacting with AWS DynamoDB.
Developed by Andrii Lototskyi
📌 Install
Run the following command in the root directory of your Node-RED installation:
This module allows performing CRUD operations and table management on DynamoDB using Node-RED.
📌 Set AWS Credentials
Before using this module, configure AWS credentials inside the DynamoDB Config Node in Node-RED:
  • AWS Access Key ID
  • AWS Secret Access Key
  • AWS Region (e.g., us-east-1)
These credentials are required for authentication with AWS DynamoDB.
Credential Sources
All connection parameters support multiple input types:
  • String: Direct value stored securely in Node-RED credentials
  • Flow Context: Retrieved from flow context variables
  • Global Context: Retrieved from global context variables
  • Environment Variable: Retrieved from environment variables
📌 Available Operations
The DynamoDB Node supports the following operations:
1️⃣ Create a Table (createTable)
2️⃣ Get an item (getItem)
3️⃣ Put an item (putItem)
4️⃣ Update an item (updateItem)
5️⃣ Delete an item (deleteItem)
6️⃣ Scan a table (scan)
7️⃣ Query a table (query)
Each operation is selected in the DynamoDB Node via the dropdown menu.
📌 Example Usage in Node-RED
1️⃣ Create a new DynamoDB Table
You can create a table with Primary Key, Sort Key (optional), and Global Secondary Index (GSI).
msg.payload = {
    "tableName": "Transactions",
    "keySchema": [
        { "AttributeName": "userId", "KeyType": "HASH" },
        { "AttributeName": "createdAt", "KeyType": "RANGE" }
    "attributeDefinitions": [
        { "AttributeName": "userId", "AttributeType": "S" },
        { "AttributeName": "createdAt", "AttributeType": "N" }
    "billingMode": "PAY_PER_REQUEST" // OR "PROVISIONED"
2️⃣ Get an item from DynamoDB
msg.payload = {
    "tableName": "Users",
    "key": { "userId": "12345" }
3️⃣ Put an item into DynamoDB
msg.payload = {
    "data": {
        "userId": "12345",
        "name": "John Doe",
        "email": "[email protected]"
4️⃣ Update an item in DynamoDB
msg.payload = {
    "key": { "userId": "12345" },
    "updateExpression": "SET email = :email",
    "expressionValues": { ":email": "[email protected]" }
5️⃣ Delete an item from DynamoDB
msg.payload = {
6️⃣ Scan a DynamoDB table
msg.payload = {
    "filterExpression": "contains(name, :namePart)",
    "expressionValues": { ":namePart": "John" }
7️⃣ Query a DynamoDB table (with Sort Key and GSI support)
msg.payload = {
    "indexName": "TransactionIndex",
    "keyConditionExpression": "userId = :userId AND createdAt >= :startDate",
        ":userId": "user_123",
        ":startDate": 1700000000
    "projectionExpression": "userId, amount, createdAt"
☝ This will retrieve all transactions for user_123, filtering those created after timestamp 1700000000.
📌 Features & Improvements
✅ Supports all CRUD operations in DynamoDB
✅ Table creation with HASH key, RANGE key, and GSI support
✅ Billing Mode (PAY_PER_REQUEST or PROVISIONED) is configurable
✅ AWS SDK v3 with @aws-sdk/lib-dynamodb for automatic data conversion
✅ Projection and filter expressions for more optimized queries
✅ Supports Global Secondary Index (GSI) and Sorting
✅ Configured directly via Node-RED UI (no settings.js required)
✅ Easy to configure and extend
📌 Support & Issues
If you find any issues, please report them at:
GitHub Issues
📌 Author & License
  • Author: Andrii Lototskyi
  • License: ISC
  • Repository: GitHub
🚀 Happy coding with Node-RED & AWS DynamoDB! 🎉
Version: 1.1.1
Updated 10 months ago
Rating: 5.0 3
4 in the last week
  • dynamodb-variable
  • dynamodb-variable-config
  • dynamodb
  • aws
  • database
  • iam
  • credentials
  • context
