node-red-contrib-dwd-weatherforecast 1.4.1
Node-RED node for official DWD MOSMIX forecast (KMZ/KML) per weather station. Parses the forecast, normalizes it, and outputs a structured JSON time series.
npm install node-red-contrib-dwd-weatherforecast
A Node-RED node that retrieves local weather forecasts from the Deutscher Wetterdienst (DWD) using the official MOSMIX_L open data products.
The node downloads the KMZ file for a given DWD station, extracts and parses the KML content and returns a structured JSON payload that is easy to consume in dashboards, notifications or further processing nodes.
✨ Features
  • Uses official DWD MOSMIX_L forecast data (hourly resolution)
  • Works with any DWD single station ID (e.g. H721 for Cologne/Bonn)
  • Supports auto-refresh (periodic updates, no inject node required)
  • Optional fetch on deploy (immediate forecast after deployment)
  • Optional stale fallback (keep last valid data if DWD is temporarily unavailable)
  • Configurable forecast horizon (limit to next N hours)
  • Flexible unit conversions (°C, hPa, km/h, km)
  • Optional core-only mode for compact payloads
  • Optional cardinal wind direction output (windDirCardinal) in 8 or 16 sectors
  • Adds a human-readable precipitation text field
  • Fully i18n-enabled (English / German, including help text and status messages)
📦 Install
From your Node-RED user directory (typically ~/.node-red):
Or via the Node-RED Palette Manager:
  1. Open the Node-RED editor
  2. Menu → Manage palette
  3. Tab Install
  4. Search for node-red-contrib-dwd-weatherforecast
  5. Click Install
🔧 Configuration
The main configuration options of the node:
Name
Optional display name for the node. If left empty, a default label is used.
DWD station ID
The DWD station identifier, for example H721 for Cologne/Bonn airport.
You can look up station IDs via the DWD documentation and station lists.
Source URL
Template URL for the DWD MOSMIX_L KMZ file. By default:
https://opendata.dwd.de/weather/local_forecasts/mos/MOSMIX_L/single_stations/{station}/kml/MOSMIX_L_LATEST_{station}.kmz
The placeholder {station} will be replaced with the configured station ID (e.g. H721).
In most cases you can keep this field untouched.
Fetch on deploy
When enabled, the node performs an initial fetch shortly after the flow is deployed.
This is useful when you always want to have fresh data available without a manual trigger.
Auto-refresh (sec)
Interval in seconds for periodic updates.
  • 0 → no automatic refresh (only manual/inject-triggered)
  • > 0 → fetch forecast in this interval (e.g. 1800 = every 30 minutes)
Lead time (hours)
Limits the forecast horizon.
  • 0 → all available forecast steps
  • 24 → only the next 24 hours
  • 48 → next two days, etc.
Only future timestamps
If enabled, forecast steps in the past are filtered out and only current / future timestamps are returned.
Fallback on error (stale)
When enabled, the node returns the last successfully fetched forecast data in case of an error (network issues, DWD outage, etc.).
The _meta.stale flag in the output is set to true in this case.
Output options
  • Core fields only
    Reduces the payload to the main weather parameters (temperature, pressure, wind, precipitation, humidity, visibility).
  • Temperature in °C
    Converts Kelvin → °C.
  • Wind speed in km/h
    Converts m/s → km/h.
  • Pressure in hPa
    Converts Pa → hPa.
  • Visibility in km
    Converts m → km.
  • Wind direction as text
    Controls whether the node adds a windDirCardinal field:
    • deg → keep numeric degrees only (0–360)
    • 8 → 8 sectors (N, NE, E, SE, S, SW, W, NW)
    • 16 → 16 sectors (N, NNE, NE, ENE, E, ESE, …)
Enable diagnostics
When enabled, additional log messages are written into the Node-RED log to help with debugging and understanding the internal processing steps.
🔌 Inputs
Any incoming message triggers a forecast update using the current configuration, unless the node is already updating due to auto-refresh.
The contents of the input message are not evaluated in the current version – only the trigger matters.
📤 Outputs
The node outputs a message where msg.payload contains an array of forecast steps and additional metadata:
  "payload": [
      "ts": 1761609600000,
      "iso": "2025-10-28T00:00:00.000Z",
      "temperature": 7.7,
      "pressure": 1010.1,
      "windSpeed": 18.5,
      "windDir": 236,
      "windDirCardinal": "SW",
      "cloudCover": 69,
      "precipitation": 0.3,
      "precipitationText": "Rain (light)",
      "relHumidity": 92,
      "condition": "61",
      "visibility": 25.7
  "station": {
    "id": "H721",
    "name": "Köln/Bonn-Flughafen"
  "_meta": {
    "url": "https://opendata.dwd.de/weather/local_forecasts/mos/MOSMIX_L/single_stations/H721/kml/MOSMIX_L_LATEST_H721.kmz",
    "count": 120,
    "stale": false,
    "coreOnly": false
The exact structure depends on your configuration (unit conversions, core-only mode, visibility, wind direction options, etc.).
🔎 Status text
The node uses its status indicator in the Node-RED editor to show what it is doing:
  • loading… – fetching data from DWD
  • ready – idle, waiting for triggers or auto-refresh
  • ok – last fetch successful, shows number of points
  • error – an error occurred while fetching or parsing
  • stale (n) – serving cached (stale) data because the latest fetch failed
All status strings are localized (English / German).
🌍 Internationalisation (i18n)
All editor labels, tips, help text and runtime status messages are localized using the Node-RED i18n mechanism:
  • English:
    • nodes/locales/en-US/dwd-weatherforecast.json
    • nodes/locales/en-US/dwd-weatherforecast.html
  • German:
    • nodes/locales/de/dwd-weatherforecast.json
    • nodes/locales/de/dwd-weatherforecast.html
The Node-RED editor language (or browser language, if configured) controls which texts are displayed.
🧪 Example flow
A basic example flow is included in:
examples/weatherforecast-basic.json
It demonstrates:
  • manual triggering via Inject node,
  • configuration of the DWD station ID,
  • and inspection of the full payload using a Debug node.
Import steps:
  1. In Node-RED, open the menu → Import
  2. Choose Clipboard
  3. Paste the contents of weatherforecast-basic.json
  4. Click Import
🗺️ Roadmap
Planned enhancements:
  • Additional helper fields (e.g. “feels like” temperature)
  • Optional aggregation (min/max per day)
  • Ready-to-use dashboard examples
  • Combined flows with other DWD nodes (pollen, warnings, rain radar)
  • Extended error reporting and metrics
⚖️ License
MIT © 2025 Gerd Rütten
🧰 Changelog
See CHANGELOG.md for a detailed list of changes.
🌦 node-red-contrib-dwd-weatherforecast — bringing official DWD forecast data directly into your Node-RED flows.
Version: 1.4.1
Updated 1 year ago
34 in the last week
  • dwd-weatherforecast
  • dwd
  • forecast
  • weather
  • mosmix
  • station
  • kmz
  • kml
  • opendata
