node-red-contrib-dwd-pollen 1.2.2
Node-RED node to retrieve the official DWD pollen hazard index (s31fg.json) per region/partregion.
npm install node-red-contrib-dwd-pollen
A Node-RED node providing access to the official DWD Pollenflugvorhersage (pollen flight forecast) for 14 pollen types, with full internationalisation and a consistent interface shared with all DWD nodes.
✨ Features
  • Official DWD Pollenflugvorhersage (pollen forecast index)
  • Fully i18n-enabled (English / German)
  • Localised help pages & editor labels
  • Supports 14 DWD pollen types
  • Structured JSON output ideal for dashboards & scorecards
  • Auto-refresh mode
  • “Fetch on deploy” option
  • Diagnostics mode for debugging
  • Consistent API across all DWD-related nodes
📦 Install
From your Node-RED user directory (typically ~/.node-red):
Or via the Node-RED Palette Manager:
  1. Open the Node-RED editor
  2. Menu → Manage palette
  3. Tab Install
  4. Search for node-red-contrib-dwd-pollen
  5. Click Install
🔧 Configuration
Name
Optional display name for the node.
Auto-refresh (sec)
If greater than 0, the node fetches pollen data periodically.
Fetch on deploy
When enabled, the node performs an initial fetch shortly after the flow is deployed.
Diagnostics
Writes detailed debug information to the Node-RED log.
🔌 Inputs
Any incoming message triggers a fetch of pollen data using the current configuration.
📤 Outputs
The node outputs the DWD pollen levels in the following structure:
  "timestamp": "2025-04-05T12:00:00Z",
  "region": "Germany",
  "pollen": {
    "hazel": 1,
    "alder": 2,
    "birch": 3,
    "grass": 0,
    "rye": 0,
    "mugwort": 1,
    "ragweed": 0,
    "ash": 2,
    "oak": 1,
    "beech": 0,
    "plane": 0,
    "maple": 1,
    "willow": 2,
    "poplar": 0
Index values follow the DWD scale 0–3.
🔎 Status text
The node reports its state using status messages:
  • loading… – data is being fetched
  • ready – idle, waiting for input or refresh
  • ok – data successfully retrieved
  • error – an error occurred
These messages are fully localised.
🌍 Internationalisation (i18n)
All editor labels, help pages, tooltips and runtime messages are translated via:
  • nodes/locales/en-US/dwd-pollen.json
  • nodes/locales/de/dwd-pollen.json
The help text is also localised:
  • nodes/locales/en-US/dwd-pollen.html
  • nodes/locales/de/dwd-pollen.html
The editor language controls which version is shown.
🧪 Example flow
A basic example flow is included in:
examples/dwd-pollen-basic.json
Import via:
  1. Node-RED menu → Import
  2. Choose Clipboard
  3. Paste the JSON
  4. Click Import
This flow demonstrates:
  • Fetch-on-deploy
  • Manual triggers
  • Viewing results in Debug nodes
🗺️ Roadmap
Planned enhancements:
  • Optional regional pollen data
  • Historical pollen values
  • Dashboard visualisation components
  • Combined output for multi-day forecasts
  • Additional pollen metadata and explanations
⚠️ node-red-contrib-dwd-pollen — bringing official DWD Pollenflugvorhersage directly into your Node-RED flows.
Version: 1.2.2
Updated 1 year ago
17 in the last week
  • dwd-pollen
  • dwd
  • pollen
  • allergy
  • health
  • weather
