node-red-contrib-durable-outbox 0.9.0
Durable SQLite outbox queue for Node-RED
npm install node-red-contrib-durable-outbox
Node-RED durable outbox
A custom Node-RED module that durably queues sink deliveries in local SQLite. It provides atomic enqueue, deduplication, leased workers, bounded exponential retry, expired-lease recovery, delivery retention, and dead-letter handling.
The module requires Node.js 22 or newer because it uses the built-in node:sqlite API.
Quickstart
Install the module and create three configuration nodes, then wire four nodes:
[Data Source] → [outbox-enqueue] → persisted or duplicate
                              └─→ not persisted → [Alarm / pause source]
[Inject 5s]  → [outbox-claim]  → [Your Deliver Node] → [outbox-settle (Success)]
                               └─ [Catch] → [fn: msg.outbox.retryable=true] ─┘
  1. durable-outbox-config — Set the database path, e.g. /data/outbox/outbox.sqlite.
  2. outbox-sink-config — Point to the config above, set a Sink key (e.g. postgres-primary), and leave retry-until-expired enabled for idempotent sinks.
  3. outbox-enqueue — Select the sink config. Wire your data source into the input.
  4. outbox-claim — Select the same sink. Feed it a repeating Inject node (e.g. every 5s). Wire through your delivery node (e.g. a PostgreSQL upsert).
  5. outbox-settle — Select the same sink, set Outcome: Success. Wire the claim output (after your delivery node) into the settle input. The success path needs no message properties.
  6. On failure: add a Catch node scoped to your delivery node, wire through a Function node that sets msg.outbox.retryable = true, then into the same settle node. One settle node in Success mode handles both paths — the message property overrides the dropdown.
That's it. See the demo flows below for a complete working example with failure classification and control operations.
Owns one SQLite database and applies its schema and durability settings. Use a path on persistent local storage, such as /data/outbox/outbox.sqlite.
The config node also bounds queue depth, encoded job size, enqueue batch size, logical database use, and minimum filesystem free space. Reusable SQLite pages do not count as database use. Set the free-space reserve to zero only when another system enforces disk headroom. Size settings use MB, where one MB is 1,048,576 bytes.
Delivered history is retained for 24 hours by default and cleaned automatically in bounded batches. Cleanup starts normally with expired records. When logical database use reaches the configured high-water mark, the oldest delivered records become expendable—even within the normal retention window—until use reaches the low-water target. Before rejecting an enqueue at the database boundary, the store makes a final bounded attempt to reclaim delivered history. Pending, leased, and dead-letter jobs are never removed by this process.
The delivered retention period is therefore a target rather than a guarantee under storage pressure. This preserves ingestion and unfinished work at the cost of shortening successful-delivery history and its deduplication window.
Automatic cleanup settings are grouped into:
  • Delivered history: retention period, cleanup interval, and cleanup batch size;
  • Storage pressure: cleanup-start percentage, cleanup-target percentage, and whether delivered history may be evicted early to protect ingestion.
The defaults run at most 10,000 deletions per transaction, start pressure cleanup at 80%, and continue in yielded batches toward 70%.
outbox-sink-config
Defines one logical delivery destination and references its durable outbox. Its editor groups the policy into:
  • Identity: durable outbox and stable persisted sink key;
  • Worker capacity: lease timeout, maximum in-flight jobs, and claim batch size;
  • Retry lifecycle: bounded-attempt or maximum-age mode, age, and backoff defaults;
  • Circuit breaker: enablement, failure threshold, and cooldown.
The defaults lease and claim up to 10 jobs, so the default batch is not artificially reduced to one job. Retryable failures remain active until the 24-hour maximum age by default; select bounded-attempt mode explicitly when a sink should stop after 10 delivery attempts.
The SQLite job stores the configured sink key, such as postgres-primary, not the generated Node-RED config-node ID.
outbox-enqueue
Persists msg.payload as one durable job and emits the original message only after the commit succeeds. The payload property is configurable.
The first output emits persisted jobs and duplicates. The second output emits inputs that were not persisted because a queue, database, or filesystem capacity boundary remained after automatic cleanup. Wire the second output to an alarm, upstream pause, or source-specific durable recovery path. Repeated capacity errors are summarized rather than logged once per input.
msg.payload = {
    device_id: msg.dev_id,
    observed_at: msg.timestamp,
    value_mm: msg.value
msg.outbox = {
    dedupeKey: `depth:${msg.dev_id}:${msg.timestamp}`
The selected sink config supplies the outbox, stable sink key, and retry defaults. Optional metadata and per-job overrides come from msg.outbox by default. Providing a different sink is rejected. Use a separate enqueue node and sink config for each logical destination.
An array in msg.payload is stored as one job payload. Use a standard Split node before enqueue when each element should be persisted independently.
dedupeKey is optional. If omitted, the node hashes the resolved sink and canonical payload. A duplicate enqueue returns the existing job instead of creating another one. Job IDs are generated and managed by the outbox; callers must use dedupeKey, not msg.outbox.id, for idempotency. JSON values, Date, and Buffer instances are preserved using a versioned encoding. Unsafe values such as circular references, functions, streams, and arbitrary class instances are rejected before the transaction commits.
With retryUntilExpired: true, retryable failures ignore the attempt count and remain active until maxAgeMs. Backoff is still bounded by maxDelayMs. This is the recommended policy for idempotent PostgreSQL deliveries.
outbox-claim
Each input message leases a bounded batch of the oldest ready jobs for one sink. Lease duration, claim batch, and maximum concurrent leases come from the selected sink config. Use a standard repeating Inject node to set the polling interval and optionally trigger once when flows start. A poll fills only the remaining in-flight capacity.
Individual output mode emits one message per lease:
    payload: { /* persisted job payload */ },
    outbox: {
        sink: "postgres",
        attempts: 1,
        leaseUntil: 1725038578295,
        leaseToken: "..."
Batch output mode emits one message for the complete claim:
    payload: [
        { /* first persisted payload */ },
        { /* second persisted payload */ }
    outbox: {
        batch: [
            { id: "...", sink: "postgres", leaseToken: "...", attempts: 1 },
The payload array can pass through one atomic PostgreSQL batch statement. msg.outbox.batch preserves every corresponding lease and is passed unchanged to outbox-settle; no Batch, Join, packing, or fan-out nodes are required.
An expired lease is eligible for recovery by another poll. Each new claim gets a fresh lease token. Settlement requires that token, so a slow worker cannot settle a job after another worker has reclaimed it.
A payload that cannot be decoded is quarantined to the dead-letter table with failure class outbox-corruption, at a maximum of ten rows per poll. Healthy rows in the same claim can continue. These records remain inspectable but cannot be replayed without external repair. An unknown versioned payload encoding pauses the sink instead, protecting data that may require a newer module version.
After the configured number of consecutive circuit failures, claims for that sink pause for the circuit-breaker cooldown. Claims become eligible again after the cooldown, and a successful delivery closes the circuit.
outbox-settle
Settles msg.outbox.id using the selected sink config. A message whose durable sink key does not match that config is rejected. Configure separate instances for success, retryable failure, or non-retryable failure. The configured outcome is the default, and msg.outbox.retryable always overrides it:
msg.outbox.retryable = true;              // retry with backoff (overrides dropdown)
A settle node set to Success handles both paths: the success wire needs no extra properties; the failure wire only needs msg.outbox.retryable. Advanced users can override the derived circuit and failure class with msg.outbox.circuitFailure, msg.outbox.failureClass, and msg.outbox.error.
The first output receives delivered jobs and scheduled retries. The second output receives jobs moved to the dead-letter table. A stale settlement is returned with msg.outbox.result.state === "stale_lease" and does not change the job or circuit state.
When msg.outbox.batch is present, every preserved lease is settled. A failed database batch contributes at most one circuit failure, while retry and dead-letter decisions remain per job. msg.outbox.result groups the results into delivered, retrying, dead, and stale arrays. If a batch contains both retrying and dead jobs, the first output receives the active lease subset and the second receives the dead-letter subset.
outbox-control
Provides message-driven operations inside a normal Node-RED flow. The selected sink supplies both its stable key and parent outbox, so the node does not need a second Outbox selector. An action can be fixed in the editor or supplied dynamically:
msg.outbox.action = "resume";
msg.outbox.sink = "postgres";
Supported actions are:
  • status, pause, resume, and retry-now;
  • list-dead, requeue-dead, and requeue-one;
  • delete-dead for exact, reviewed dead-letter deletion by ID;
  • purge-delivered for bounded retention cleanup;
  • maintenance for WAL checkpointing and an explicitly requested vacuum;
  • check-integrity for schema, trigger, queue-counter, and SQLite checks.
resume closes the sink circuit and makes all pending work immediately eligible. Results are returned in both msg.payload and msg.outbox.result.
Feed a repeating Inject into a control node configured for status to keep a compact sink badge current. Its fixed queue-first layout omits zero counts:
q263 · age 18m · 10 🪽 · 13 🥀 · 2 ☠️
The symbols mean leased, previously failed but still pending, and dead-lettered jobs. Pauses, open circuits, expired leases, and storage pressure replace the normal state while preserving the q… prefix. Dead letters remain visible but do not make an otherwise healthy or actively processing sink red; badge color and shape primarily describe current throughput. The emitted payload remains structured and includes the exact display object passed to Node-RED. Other control actions use their existing return values for queue-first acknowledgements such as q263 · paused ⏸, q276 · 13 requeued ♻️, and q263 · integrity ok ✓; they do not run an additional full status query.
status is scoped to the selected sink while including its parent outbox's storage health. purge-delivered, maintenance, and check-integrity operate on the entire parent outbox. Dead-letter and retry controls default to the selected sink key; msg.outbox.sink can override that key within the same outbox. Bulk replay skips outbox-corruption records and reports them as corruptSkipped.
Tests
Run the complete test suite:
npm test
The tests cover:
  • atomic rollback for multi-job enqueue;
  • canonical deduplication;
  • Date/Buffer serialization and unsafe-payload rejection;
  • maximum in-flight enforcement;
  • bounded batch claiming;
  • native batch messages and batch-aware settlement;
  • expired lease recovery;
  • stale-worker lease fencing;
  • bounded exponential backoff with jitter;
  • successful delivery retention;
  • retry exhaustion and non-retryable dead letters;
  • dead-letter replay;
  • retry-until-expired infrastructure policy;
  • per-sink circuit breaking and manual resume;
  • filtered bulk dead-letter replay;
  • SQL-filtered dead-letter listing;
  • bounded retention, deletion, health, and capacity controls;
  • managed-ID enforcement and distinct storage admission failures;
  • corrupt-payload quarantine and unknown-encoding sink pauses;
  • explicit integrity checks and startup queue-counter reconciliation;
  • the No-SQL write-plan demo's structure, Function syntax, cross-realm object validation, and batch lease partitioning;
  • registration and message behavior of all six Node-RED node types.
Stress and outage tests
The primary stress suite uses an on-disk SQLite outbox and a deterministic asynchronous sink simulator. It does not require Docker or PostgreSQL:
npm run test:stress
The suite measures growing-backlog enqueue latency, claim/settle drain throughput, event-loop delay, database/WAL size, and expired-lease cleanup. Its Node-RED scenario opens the circuit during a simulated outage, verifies that the entire backlog remains durable, resumes the sink, drains every job exactly once, and fences a slow response after its lease is reclaimed. A separate process is killed with outstanding leases to verify WAL integrity and restart recovery. Metrics are emitted as single-line STRESS_METRICS JSON records for collection by CI.
The default profile uses 5,000 jobs. Larger or environment-specific profiles can be selected without changing the tests:
STRESS_JOBS=100000 \
STRESS_EXPIRED_JOBS=100000 \
STRESS_BATCH_SIZE=100 \
STRESS_MAX_IN_FLIGHT=500 \
npm run test:stress
Available performance budgets are:
  • STRESS_MIN_JOBS_PER_SECOND — minimum direct-store enqueue throughput (default 100);
  • STRESS_MAX_EVENT_LOOP_P99_MS — maximum simulated-flow p99 event-loop delay (default 250);
  • STRESS_MAX_STORE_MS and STRESS_MAX_SUITE_MS — per-test timeout budgets (default 120000).
These deliberately portable defaults catch severe regressions. Record metrics on the intended production hardware and tighten the budgets there.
PostgreSQL remains an optional integration smoke test for the real node-red-contrib-postgresql message contract. With the Compose demo already running, verify that new readings reach PostgreSQL:
docker compose up --build -d --wait
npm run test:postgres
This smoke test is intentionally separate from both npm test and the simulated outage suite.
Docker Compose PostgreSQL demo
Build and start Node-RED and PostgreSQL:
Open Node-RED. The demo creates one sensor reading every two seconds, commits it to SQLite, leases it to a PostgreSQL worker, and acknowledges it only after the upsert succeeds. Delivery uses node-red-contrib-postgresql 0.15.4 with an environment-configured connection pool and a parameterized msg.query / msg.params upsert. The Durable PostgreSQL outbox demo tab shows individual delivery. The Batch outbox tab claims one payload array with its msg.outbox.batch leases, executes one PostgreSQL unnest upsert, and passes the batch directly to batch-aware settlement.
The host ./demo directory is mounted at /data, so deploying in the Node-RED editor writes directly to ./demo/flows.json and changes survive container restarts. Mounting the containing directory is intentional: Node-RED saves by writing a temporary file and atomically renaming it over flows.json, which cannot work when flows.json itself is an individual Docker bind mount. The SQLite outbox remains separately persisted in ./data/outbox.
No-SQL write-plan and batch demo
demo/flows_nosql.json is an alternate, editable flow showing how a producer can describe writes without owning SQL:
msg.payload = {
    version: 1,
    eventId: "stable-source-event-id",
    writes: {
        sensor_readings: [{
            device_id: "sensor-1",
            observed_at: "2026-07-28T12:00:00.000Z",
            value_mm: 12.5
        sensor_health: [{
            batt_mv: 3710,
            rssi_dbm: -67
Start that flow instead of the main demo:
FLOWS=flows_nosql.json docker compose up --build -d --wait
The flow durably enqueues each WritePlan as one job, then claims jobs in batches. A single allowlisted registry validates table names, exact columns, types, required values, conflict keys, explicit conflict-update columns, and table order. Its closed type catalog maps logical types such as float and timestamptz to both validation rules and trusted PostgreSQL types, so producers cannot supply SQL fragments. Optional columns are deliberately rejected until their insert-default and conflict-update behavior is explicitly defined. Invalid plans are split out with their matching leases and dead-lettered as data; valid plans are collated by table and compiled into one parameterized PostgreSQL statement. Data-modifying CTEs and jsonb_to_recordset make all table upserts one atomic transaction. A PostgreSQL failure therefore retries the complete valid lease subset without partially acknowledging it.
The registry and plan version form part of the durable sink protocol. Every subflow instance that shares a sink key must use the same registry. Change the version suffix in the sink key when making an incompatible plan or registry change; otherwise a worker can claim a persisted job it does not understand.
The producer runs at five plans per second while the worker polls once per second, so each execution normally demonstrates a five-row batch. Click enqueue invalid plan to exercise validation and the dead-letter output. The operation group includes status, resume, and dead-letter inspection controls.
Durable error logging
The same demo includes Log Error → Durable WritePlan. Logger instances sanitize caught Node-RED errors and enqueue an errors WritePlan directly to the selected sink. They do not contain claim pollers; one shared No-SQL Outbox instance owns PostgreSQL delivery for the sink. This avoids creating one worker for every Catch/Log Error instance.
The plan stores a stable event_id derived from the source node, Node-RED message ID, and error occurrence. Both the outbox dedupe key and PostgreSQL conflict key use that identity. Nested Error objects, circular causes, dates, buffers, and oversized diagnostic structures are converted to bounded JSON before enqueue.
For an existing errors table, apply this once before using the new logger:
ALTER TABLE errors
    ADD COLUMN IF NOT EXISTS event_id TEXT;
CREATE UNIQUE INDEX IF NOT EXISTS errors_event_id_time_uidx
    ON errors (event_id, time);
Including time makes the unique index compatible with a TimescaleDB hypertable partitioned on that column. Existing rows may leave event_id null; every new error plan supplies it. The demo's fresh-table bootstrap already creates the equivalent constraint.
Because ./demo is mounted as a directory, editor deployments save this alternate flow directly to ./demo/flows_nosql.json. Return to the normal demo with:
docker compose up -d --wait --force-recreate node-red
Inspect delivered rows:
docker compose exec postgres \
  psql -U floodnet -d floodnet_demo \
  -c "SELECT * FROM sensor_readings ORDER BY observed_at DESC LIMIT 10"
Demonstrate outage recovery:
docker compose stop postgres
docker compose logs -f node-red
docker compose start postgres
While PostgreSQL is stopped, Node-RED continues committing generated readings to the outbox-data volume, applies bounded backoff, and opens the PostgreSQL circuit after repeated failures. Once the cooldown expires and PostgreSQL is available, a successful probe closes the circuit and the worker drains the pending jobs. These demo jobs retry for up to seven days and do not dead-letter merely because their attempt count grows.
To inspect the SQLite queue from the host without modifying it:
docker compose exec node-red node -e \
  'const {DatabaseSync}=require("node:sqlite"); const db=new DatabaseSync("/data/outbox/outbox.sqlite"); console.table(db.prepare("SELECT sink,state,count(*) count FROM outbox_jobs GROUP BY sink,state").all())'
Message-driven operations
The demo includes visible Inject → outbox-control → Debug flows for:
  • inspecting queue and circuit state;
  • resuming PostgreSQL and immediately draining pending work;
  • bulk-requeueing expired PostgreSQL infrastructure failures.
The same node can be driven dynamically by a Dashboard button, MQTT command, authenticated HTTP-In flow, or another operational workflow:
msg.outbox.action = "requeue-dead";
msg.outbox.sink = "postgres-demo";
msg.outbox.failureClass = "infrastructure";
msg.outbox.limit = 1000;
To replay one reviewed dead letter:
msg.outbox.action = "requeue-one";
msg.outbox.deadLetterId = "the-job-id";
To delete dead letters only after list-dead has returned and downstream processing has durably handled them:
msg.outbox.action = "delete-dead";
msg.outbox.deadLetterIds = archivedJobs.map((job) => job.id);
Deletion is exact and idempotent. Already deleted or requeued IDs are reported in msg.outbox.result.missingIds; filter-based bulk deletion is not supported.
To purge at most 1,000 delivered records older than one day:
msg.outbox.action = "purge-delivered";
msg.outbox.olderThanMs = "24h";
After cleanup, checkpoint the WAL. Vacuum is opt-in because it can block ingestion:
msg.outbox.action = "maintenance";
msg.outbox.vacuum = false;
There are no built-in HTTP management endpoints. Authentication, authorization, auditing, and operator presentation remain part of the surrounding Node-RED flow.
Operational notes
  • Mount the SQLite directory on persistent local storage. Do not place the WAL database on NFS.
  • Monitor status health fields for queue depth, oldest queued age, expired leases, dead-letter count, logical database use, reusable pages, filesystem free space, capacity state, cleanup totals, pressure evictions, and startup integrity. Pressure eviction indicates that the effective delivered-history and deduplication window was shortened to preserve ingestion.
  • Wire the second outbox-enqueue output and alert on OUTBOX_DATABASE_CAPACITY, OUTBOX_QUEUE_CAPACITY, and OUTBOX_DISK_HEADROOM. A database-capacity rejection means no reclaimable delivered history remained; filesystem headroom remains an independent hard boundary.
  • Run check-integrity periodically and investigate ok: false before resuming ingestion. Startup recreates the queue-count triggers and reconciles their counters transactionally.
  • A worker lease should exceed the sink's connection and request timeout.
  • Automatic bounded delivered-history cleanup is owned by the durable outbox; an Inject node is not required. Keep purge-delivered for operator-requested cleanup. Run an optional maintenance vacuum only during a quiet window.
  • The outbox gives PostgreSQL effectively-once behavior because the demo uses an idempotent upsert. External HTTP sinks still need an idempotency key to avoid duplicates after an ambiguous timeout.
Version: 0.9.0
Updated 3 months, 1 week ago
139 in the last week
  • durable-outbox-config
  • outbox-sink-config
  • outbox-enqueue
  • outbox-claim
  • outbox-settle
  • outbox-control
  • outbox
  • sqlite
  • retry
  • dead-letter
