node-red-contrib-dulonode 1.0.15
Alexa voice control for Node-RED, set up in minutes - no coding or custom skill to build.
npm install node-red-contrib-dulonode
DuloNode simplifies home automation by integrating Amazon Alexa with Node-RED. It serves as a bridge between Alexa voice commands and Node-RED payloads, providing reliable communication through an Alexa Skill. By using DuloNode, you can create dynamic and flexible home automation systems with minimal setup.
DuloNode Example Flow
Example Commands
  • "Alexa, turn on the living room light."
  • "Alexa, set the thermostat to 21 degrees."
  • "Alexa, close the garage door."
  • "Alexa, dim the bedroom lamp to 50%."
  • "Alexa, make the fan speed low."
Supported Devices
Device Type Features
Battery Charge Level, State, Time Remaining, Temperature
Blind Lift Control
Charging Station On/Off, Charging Mode, Current Control
Fan On/Off, Speed Control, Oscillation
Garage Door Open/Close
Light On/Off, Brightness, Color, Temperature
Lock Lock/Unlock
Scene Scene Activation
Speaker Playback, Volume Control
Switch On/Off
Thermostat Temperature Control, Modes, Sensors
TV On/Off, Volume, Channels, Input Selection
Setup Overview
Getting started with DuloNode is quick and straightforward. The setup consists of the following steps:
  1. Create a DuloNode account
    Sign up for a DuloNode account at https://www.dulonode.com. This account is used to link Alexa with your Node-RED flows.
  2. Enable the DuloNode Alexa Skill
    Enable the DuloNode skill from the Amazon Alexa Skill Store and link it using your DuloNode account. The skill is available in multiple locales, including English, French, German, Italian, Portuguese, and Spanish.
  3. Set up Node-RED
    Install the node-red-contrib-dulonode module, import the provided basic flow, and sign in using the DuloNode Hub node.
  4. Discover your devices
    Once deployed, ask Alexa to discover devices. Your Node-RED flows will be exposed to Alexa and ready for voice control.
For full setup instructions, supported devices, JSON payloads, and detailed configuration guides, visit the official DuloNode website:
Version: 1.0.15
Updated 2 weeks, 1 day ago
License: SEE LICENSE IN LICENSE.md
Rating: 4.4 16
606 in the last week
  • DuloNodeHub
  • DuloNodeDevice
  • alexa
  • amazon-echo
  • home-automation
  • smart-home
  • home-assistant
