node-red-contrib-dotnsf-gpt 1.1.2
npm install node-red-contrib-dotnsf-gpt
GPT(3.5) based query Node for Node-RED
Overview
Query-able node based on GPT(3.5)
Pre-requisite
You need to get (free)account in Open AI API beta first.
You also have to prepare API Key here.
At last, you would prepare Node-RED.
How to use
  1. In Node-RED, you can search node-red-contrib-dotnsf-gpt node. You need to install this node in your Node-RED.
  1. You will see GPT node under function category. Drag & Drop this node into Node-RED's canvas.
  1. In Node-RED canvas, setup input node(Injection), output node(Debug), and GPT node between them. You need to wire them.
  1. Open properties box. You need to edit API Key field with your API Key. You can change other properties, but leave them as default now.
  1. You also need to input query text in Injection node. For example, "IBM Cloud について教えて". In Injection node, this text would be send in msg.payload.
  1. Now you can deploy this flow with upper-right button.
  1. After deployment, you can click left-side button in Injection node to send query text into GPT node.
  1. GPT node needs about 5-10 seconds to query. While waiting for reply, GPT node shows green status indicator.
  1. After replied, GPT node send result in msg.payload. In this flow, Debug node would output query result in debug window.
Licensing
This code is licensed under MIT.
Copyright
2022 K.Kimura @ Juge.Me all rights reserved.
Version: 1.1.2
Updated 4 years, 2 months ago
  • GPT
  • dotnsf
  • gpt
