node-red-contrib-domotz 1.0.2
A collection of Node-Red nodes to access the Domotz public API
npm install node-red-contrib-domotz
Node Red Domotz
This node helps performing API calls to the Domotz Public API. API parameters can be set in the configuration section or via node's input. The node automatically converts url and query parameters.
Inputs
An optional payload with the operation's parameters, e.g.:
{"params": {"agent_id": "xyz"}}
Static parameters can be alternatively defined in the configuration of the node. Required parameters are marked with an *. Using the "Browse" option you can select agents, devices and sensors by name (note that this feature will use some of your API budged to retrieve the necessary resources).
Outputs
  • Output:
    • payload.code: The HTTP code
    • payload.message: the payload of the HTTP response
    • payload.headers: the HTTP response headers
    • payload.configParams: the configuration parameters of the node
    • payload.inputParams: the input parameters of the node
  • Errors:
    • payload.code: The HTTP error code
    • payload.message: The HTTP response content
References
Domotz Developers - Domotz API Documentation
Domotz Portal - subscribe and get an API-Key
Domotz Website
Screenshots
Node configuration
Flow example
Visualization (with node red dashboard)
Version: 1.0.2
Updated 6 years, 2 months ago
License: GPL-3.0
18 in the last week
  • domotz-api
  • domotz-api-conf
  • domotz
  • node
  • rmm
  • msp
  • home-automation
  • network
  • monitoring
