node-red-contrib-docxtemplater 1.0.10
Generate docx, pptx, and xlsx from templates (Word, Powerpoint and Excel documents), from Node-Red
npm install node-red-contrib-docxtemplater
node-red-contrib-docxtemplater is a Node-RED node that enables you to generate Word documents (.docx) by dynamically filling templates using Docxtemplater. With this node, you can create rich, personalized Word documents directly from Node-RED, making it ideal for report generation, invoices, and custom documents.
To install, run the following command in your Node-RED directory:
npm install omerkaptan/node-red-contrib-docxtemplater
  1. Template Creation: Start by creating a .docx template with placeholders formatted as tags, like {{name}}, {{date}}, or {{items}}. Tags are placeholders that Docxtemplater will replace with actual values.
  2. Template Input: Provide the .docx template to the node, either as a file path or binary input.
  3. Data Input: Send data as a JSON object, mapping each tag to a value (e.g., { "name": "Alice", "date": "2024-10-30" }).
  4. Output: The node outputs a .docx document where each placeholder is replaced by the data you've provided.
Examples
Here are some specific tag usage examples you can use with your .docx templates:
  • Simple Text Replacement: Replace {{name}} with a name:
    { "name": "Alice" }
  • Looping Over Arrays: To add a list of items in a table format, use the {{#items}}...{{/items}} tag structure in your .docx template, and pass an array of objects as shown below:
      "items": [
        { "description": "Item 1", "price": 10 },
        { "description": "Item 2", "price": 15 }
  • Conditional Tags: Use conditional tags to show or hide content based on a value:
    { "isApproved": true }
    In your template, use tags like {{#isApproved}}Approved{{/isApproved}} to display "Approved" only if isApproved is true.
For more advanced tag types and formatting options, see the full Docxtemplater Tag Types documentation.
Example Flow
  1. Template Node: Use a file input node to load the .docx template.
  2. Data Node: Add a JSON node with the structured data to fill in placeholders.
  3. Docxtemplater Node: Connect the template and data nodes to the docxtemplater node.
  4. Output Node: Use a file output node to save the generated .docx document.
Dependencies
This node depends on Docxtemplater for template processing, so refer to their documentation for further customization options.
MIT License
Version: 1.0.10
Updated 2 years, 2 months ago
Rating: 3.7 3
153 in the last week
  • docxtemplater
  • docx
  • pptx
  • templates
  • template
  • templater
  • templating
  • report
  • xlsx
  • generation
  • generate
  • generator
  • microsoft office
  • microsoft word
  • microsoft powerpoint
  • microsoft excel
  • create
  • make
  • Office Open XML
  • creator
  • Ă–mer Kaptan
