node-red-contrib-display-property 1.1.0
A Node-RED node that displays the value of a message property as node status, optionally including the date and time.
npm install node-red-contrib-display-property
A simple Node-RED node that displays the value of a message property as the node status.
The node is intended to make flows easier to observe and debug without adding a separate Debug node for every value you want to watch. It can optionally prepend the current date and/or time to the displayed value.
  • Displays a configurable msg property as the node status
  • Supports nested properties such as msg.payload.temperature
  • Optional date display in YYYY-MM-DD format
  • Optional time display in HH:MM:SS format
  • Supports per-message property override using msg.property
  • Passes the incoming message through unchanged
  • Backward compatible with existing configurations that store properties with a leading msg.
Install from the Node-RED Manage palette dialog, or from your Node-RED user directory with:
Restart Node-RED after installation if required.
Name
Optional name for the node.
Property
Select the message property to display.
The default property is:
msg.payload
Nested properties are supported, for example:
msg.payload.room.temperature
msg.topic
If the configured property does not exist in the incoming message, the status displays:
Show date
When enabled, the current local date is prepended to the status in:
YYYY-MM-DD
Show time
When enabled, the current local time is prepended to the status in:
HH:MM:SS
When both options are enabled, the status begins for example with:
2026-08-24 14:35:12:
Per-message property override
An incoming message may contain msg.property.
If it contains a non-empty property name, that value overrides the property configured in the editor for that message only.
Example:
msg.property = "msg.topic";
msg.topic = "Heating";
The node will display the value of msg.topic for this message. The configured property remains unchanged for subsequent messages.
Both of these forms are accepted:
payload.temperature
Message handling
The node only reads the incoming message. It does not add, remove, or modify message properties.
The same message is passed to the output.
Example
Incoming message:
  "payload": {
    "temperature": 21.7
Configured property:
Displayed node status:
21.7
Version 1.1.0
Version 1.1.0 modernizes and hardens the node while preserving compatibility with existing flows and Node-RED 1.0 or later.
Changes include:
  • fixed msg.property handling so it affects only the current message
  • fixed handling of empty or invalid msg.property values
  • added reliable support for nested message properties
  • removed unintended modification of incoming messages
  • modernized the Node-RED input handler with send and done
  • changed date/time settings to Boolean values
  • added a Node-RED TypedInput for message properties
  • improved the editor help text
  • retained compatibility with old property strings such as msg.payload
MIT
Version: 1.1.0
Updated 3 weeks, 3 days ago
13 in the last week
  • display property
  • property
  • debug
  • display
  • status
