node-red-contrib-display 0.7.11
A live, resizable Markdown and HTML display node for the Node-RED editor.
npm install node-red-contrib-display
Display adds live, resizable Markdown and HTML cards to the Node-RED editor. Values from incoming messages, flow context, global context, and environment variables can be displayed directly on the flow canvas.
Display node showing live content in the Node-RED editor
  • Render sanitized Markdown directly inside the editor.
  • Render interactive HTML inside a sandboxed document.
  • Insert live values using placeholders such as ${msg.payload} and ${msg.sensor.temperature}.
  • Read values from message, flow, global, and environment scopes.
  • Embed links, images, tables, websites, dashboards, and supported videos.
  • Resize and zoom displayed content directly on the flow canvas.
  • Remember previously received placeholder values.
  • Flatten the node to display only its rendered content.
  • Use transparent backgrounds for custom HTML designs.
  • Hide scrollbars when content overflows.
  • Limit the maximum display update rate.
Behaviour
A display can be designed almost entirely through Markdown, HTML, CSS, and JavaScript. However, it should primarily be used for visualization rather than as a complex script execution environment. The visual output is intended for use inside the Node-RED editor. It is not a replacement for a standalone Node-RED Dashboard or external web interface. Complex displays can consume browser and runtime resources. Consider disabling displays that are no longer needed, especially before deploying a finished flow to a production machine.
Placeholders
Placeholders can be used in both Markdown and HTML:
${msg.payload}
Use explicit scopes whenever possible:
Message: ${msg.topic}
Message Nested: ${msg.payload.temperature} °C
Flow: ${flow.room}
Global: ${global.site.name}
Environment: ${env.name}
Nested object paths are supported. Objects and arrays are rendered as JSON.
Markdown and HTML
Markdown mode
Markdown is sanitized before it is displayed. Safe embedded HTML can also be included.
The sandbox prevents the display from directly accessing the Node-RED editor page.
Iframe content may still be blocked by:
  • The target website
  • Browser security policies
  • The Node-RED editor's content security policy
  • X-Frame-Options or Content-Security-Policy headers
Example usage of displays
Example 01: Zooming
Zooming a Display node on the Node-RED flow canvas
Example 02: Live data
Display values from incoming Node-RED messages.
Displaying live message data in a Node-RED flow
Example 03: Multiple live values
Use multiple placeholders to update different parts of a display.
Updating multiple live values inside a Display node
Example 04: Live status
Create live status indicators using message values and custom styling.
Live status indicators rendered inside a Display node
Example 05: Memory
Preserve older placeholder values when messages contain only partial updates.
Display memory preserving values between partial message updates
Example 06: GIFs and images
Embed animated GIFs and regular images inside a display.
Animated GIF and image content embedded in a Display node
Example 07: Websites
Embed supported websites using an iframe.
Website embedded inside a Display node using an iframe
Example 08: Node-RED Dashboard
Display an existing Node-RED Dashboard directly on the flow canvas.
Node-RED Dashboard embedded inside a Display node
Example 09: YouTube video
Embed supported YouTube videos using the YouTube embed URL.
YouTube video embedded inside a Display node
Example 10: Resizing
Resize the display to fit different types of content.
Resizing a Display node on the Node-RED flow canvas
Example 11: Scrollbars
Allow or hide scrollbars when content exceeds the available display area.
Scrollable content inside a Node-RED Display node
Example 12: Responsive updates
Render rapidly changing values while controlling the maximum update rate.
Responsive live updates rendered inside a Display node
Security
Displayed context and environment values are visible to anyone with access to the Node-RED editor. HTML displays can also execute JavaScript and make network requests. Only use HTML and JavaScript that you trust. Do not display passwords, API keys, access tokens, or other secrets.
Requirements
  • Node-RED 5.0 or newer
  • Node.js 22.9 or newer
Contact
Found a bug, have a suggestion, or want to discuss the node?
Licensed under the MIT License.
Version: 0.7.11
Updated 4 months ago
  • display
  • node-red-contrib
  • display
  • markdown
  • monitor
  • editor
