node-red-contrib-discovery-insert 0.1.7
A node for inserting documents into the watson discovery service.
npm install node-red-contrib-discovery-insert
Watson Discovery insert node.
This is a set of nodes for working with the IBM Watson Discovery service. IBM Watson™ Discovery makes it possible to rapidly build cognitive, cloud-based exploration applications that unlock actionable insights hidden in unstructured data — including your own proprietary data, as well as public and third-party data.
This package offers two nodes
Insert - For publishing documents to watson discovery. Update - For updaging documents already in the service
The nodes both contain quing systems, and will auto retry if discovery responds with a 429 ( busy ). In the node you can define that maxiumum number of items to queue up, and how long in milliseconds to wait between retrys.
Example Useage
Insert JSON data, via a function node connected to insert node:
msg.datatype = "JSON"
msg.payload = {
              sampledata:"some data goes here"
Update Binary file (e.g pdf/word) , via a function node connected to an update node:
msg.datatype = "BIN"
msg.payload = {
              content = msg.payload.content //This should be a Buffer from an fs.readFileSync(),
              fileName = "updated_doc_v2.pdf"
msg.document_id = "6022b729-f180-4772-88a7-f73333594ead"
Setting the Collection or Eniviroment ID dynamicly:
msg.payload = {
msg.environment_id = "env_id";
msg.collection_id = "collection_id"
Version: 0.1.7
Updated 9 years, 4 months ago
10 in the last week
  • discovery-insert
  • discovery-update
