node-red-contrib-discovergy-meter 0.7.3
Allows to work with a Discovergy Smart Meter (Electricity only) within Node RED flows
npm install node-red-contrib-discovergy-meter
casa-corrently
Allows to work with a smartmeters (Electricity only) within Node RED flows. If you do not have a Smart Meter you might get it here from STROMDAO (Germany only).
npm Build Status Code Quality chat CO2Offset
NOTE: new name
This package gets renamed into casa-corrently - Previous: node-red-contrib-discovergy-meter
Node-RED (Node) via Shell
cd ~/.node-red/
npm install --save node-red-contrib-discovergy-meter
Node-RED (Node) via Editor
Install node-red-contrib-discovergy-meter as NODE package.
QuickStart
This QuickStart allows you to start node-red with one the sample meters to get quickly familiar with this Node (module).
Prerequisites
Corrently Demo Meter(s) - Full generation (Messkonzept1 - Volleinspeisung)
Reference: https://casa.corrently.de/books/demo-z%C3%A4hler/page/messkonzept-1-%28volleinspeisung%29
npm run demo-messkonzept1
Corrently Demo Meter(s) - surplus feed-in (Messkonzept2 - Überschusseinspeisung)
Reference: https://casa.corrently.de/books/demo-z%C3%A4hler/page/messkonzept-2-%28%C3%BCberschusseinspeisung%29
npm run demo-messkonzept2
Accessing Demo
First time usage
On first time adding a Discovery Meter to a flow the list of available meters will be empty.
  • Add Discovergy login information to configuration node
  • Deploy changes to flow
  • Re-Open Configuration of Discovergy Meter
Modify time and reading of installation (optional)
You might overwrite time and value of first reading from the node configuration.
Output (standard)
If triggered (maybe periodic via an inject) this node provides a json Object as msg.payload.
msg.payload =  {
  time: <TIME>, // time of reading per Discovergy API
  latest: {
    power: <POWERVALUE>, // Power in Watt * 10^-3
    power1: <POWERVALUE>,// Power in Watt * 10^-3 of Phase 1
    power2: <POWERVALUE>,// Power in Watt * 10^-3 of Phase 2
    power3: <POWERVALUE>,// Power in Watt * 10^-3 of Phase 3
    energy: <ENERGYVALUE>,// Actual Meter Reading in Watthours * 10^-7 (consumption . OBIS Code 1.8.0)
    energyOut: <ENERGYVALUE>,// Actual Meter Reading in Watthours * 10^-7 (production . OBIS Code 2.8.0)
    baseCosts: <EUROVALUE>, // Accumulated base fee (Grundgebühr) since first measument time (eq. installation - might be overwritten)
    energyCost: <EUROVALUE>, // Accumulated energy costs (Arbeitspreis) since first measument time (eq. installation - might be overwritten)
    energyRevenue: <EUROVALUE>, // Revenue from feeding Energy into the grid
    incomeSaldo: <EUROVALUE> // Pre Calculated : energyRevenue - (baseCosts + energyCost)
Output with statistics (advanced)
If msg.topic is set to statistics additional statistic information will be provided. Beside of power,power1,power2,power3 the object gets formated same as in msg.payload.latest above.
*NOTE: Retrieving statistics requires a significant higher amount of API calls. Consider to use it less than once per minute. *
msg.payload =  {
  time: <TIME>// time of reading per Discovergy API
  latest: { ... }, // latest values
  last24h: { ... }, // From latest reading 24 hours backward
  today: { ... }, // Values from today
  yesterday: { ... }, // Values from yesterday
  monthToDay: { ... }, // Values from this month
  lastMonth: { ... }, // Values from last month
  yearToDay: { ... }, // Values from this year
  last365d: { ... } // Values from last 365 days
Output with aggregation (advanced)
You might add multiple Discovergy Meters in sequence. In this case a property aggregation will contain aggregated values of all meters.
msg.payload =  {
  aggregation: { ... } // Aggregated values of all meters in sequence
Sample flows
Messkonzept 2 (Überschußeinspeisung) ohne Z2 (Produktionszähler)
Dashboard
Standalone usage
It is possible to run this node without Node-RED. It comes shipped with a express APP.
git clone https://github.com/energychain/node-red-contrib-discovergy-meter.git
cd node-red-contrib-discovergy-meter.git
npm install
npm start ./sample_config_messkonzept2.json
Prosumer Display
Online Demo (via Heroku): https://casa-corrently-demo.herokuapp.com/index.html
By default the Web UI will be visible at http://localhost:3000/index.html
One Click Deployment
Heroku: https://heroku.com/deploy?template=https://github.com/energychain/node-red-contrib-discovergy-meter
Funding
This module is part of the Corrently Ecosystem which looks for funding in Germany: https://www.stromdao.de/crowdfunding/info STROMDAO - Corrently Crowdfunding
Further reading
Further Documentation is available as Casa Corrently Chapter at: https://casa.corrently.de/books/nutzung-von-node-red/chapter/gr%C3%BCnstromz%C3%A4hler-%28discovergy-meter%29
Maintainer / Imprint
This module is not an official contribution by Discovergy GmbH.
STROMDAO GmbH
Gerhard Weiser Ring 29
69256 Mauer
Germany
+49 6226 968 009 0
[email protected]
Handelsregister: HRB 728691 (Amtsgericht Mannheim)
LICENSE
Apache-2.0
Version: 0.7.3
Updated 4 years, 2 months ago
66 in the last week
  • discovergy-config
  • Discovergy Meter
  • Available Meters
  • discovergy
  • smartmeter
  • corrently
  • isms
  • stromzähler
  • electricitymeter
  • easymeter
  • powermeter
  • energyprice
  • strompreis
