node-red-contrib-discord-updated 4.1.0
Receive, send, edit, reply, react to and delete Discord messages, handle interactions and much more in Node-RED.
npm install node-red-contrib-discord-updated
Node-red nodes that allow you to interact with Discord, via Discord.js.
Currently the following actions are supported:
  • Receive messages from any Discord servers your BOT is in.
  • Send messages in a specific channel.
  • Send private messages to users.
  • Send and edit embed messages.
  • Add attachments to messages, including description/spoiler/audio-duration metadata.
  • Edit, reply, delete messages in a channel.
  • Publish messages to announcements channels.
  • React to messages with emojis.
  • Listen for reactions on a message.
  • Listen for interactions on a message button or select menu.
  • Listen for interactions on commands.
  • Submit modals.
  • Set Status text of the Bot
  • Get permissions of a specific user. Add and remove roles. Listen when a user joins or leaves a guild.
  • Track voice channel joins, leaves, and state updates for guild members.
  • Change channel's name.
  • Allow full control over the BOT by access to the DiscordJS client.
  • Create, update, delete and get Application commands.
  • Create, delete and get events, including stage-channel scheduling safeguards.
  • Obtain info and change name of a guild.
  • Manage guild emojis with upload validation and safe deletes.
  • List or count members of a guild role with pagination helpers.
  • Run bulk message fetch/delete flows with safety checks and notification controls.
  • Send, edit, and delete ephemeral interaction follow-ups without manual token handling.
This project began as node-red-contrib-discord by Joris vd Donk and was expanded by Mark Koudstaal in the node-red-contrib-discord-advanced fork. The stewardship now lives under chrobione/node-red-contrib-discord-updated; all of the earlier work and credits are intentionally preserved while the Discord.js feature set continues to expand.
Living plans, migration notes, and changelog entries sit inside upgradedocs/. Start with:
  • upgradedocs/programming-spec.md for the current roadmap across phases.
  • upgradedocs/task-list.md tracking day-to-day progress, upcoming features, and testing status.
  • CHANGELOG.md for user-facing updates in release order.
The current major release is 4.1.0, reflecting the palette regrouping, help rewrites, Node 20 baseline, the new interaction follow-up tooling, and metadata/doc fixes for the Flow Library scorecard.
Compatibility
  • Node-RED: >= 4.0.0
  • Node.js: >= 20.0.0
  • discord.js: 14.x (tested with 14.15.3)
Examples are bundled under examples/ and are available from the editor via Menu → Import → Examples → node-red-contrib-discord-updated.
Quick start
  • Create a Discord application with a bot token and invite it to a test guild.
  • In Node-RED, open Settings → Manage palette → Install and add node-red-contrib-discord-updated.
  • Drop a discord-token configuration node into the editor, paste your bot token, and share it with the runtime nodes below.
  • Start with a discordMessage node wired to a debug node so you can see inbound activity, then add the action nodes you need.
  • Use discordMessageManager or discordInteractionManager as your primary “send a response back” nodes once you have confirmed connectivity.
  • The palette now lists groups as discord · event intake, discord · responses, discord · guild control, and discord · advanced tools; start in Event Intake, then wire Responses, Guild Control, and Advanced Tools nodes as your flow grows.
Example flows
  • examples/interactionFollowupLifecycle.json — shows an end-to-end slash-command response with an ephemeral initial reply, a follow-up message, an edit, and a final clean-up using the new interaction manager actions.
  • examples/commandWithEphemeral.json — captures the classic “acknowledge publicly, DM privately” pattern using an ephemeral defer plus a direct message follow-up.
  • examples/respondingToCommands.json — demonstrates editing the original reply for message and context-menu interactions while keeping the interaction token alive.
Importing an example flow into Node-RED
  1. Open the JSON file in this repository and copy its contents to your clipboard.
  2. In Node-RED, choose Menu → Import → Clipboard.
  3. Paste the JSON, click Import, and drop the flow into your workspace.
  4. Update the discord-token config node with your bot token, then deploy to try the example.
Node groups at a glance (palette labels)
  • discord · event intake – discordMessage, discordMember, discordReactionManager, discordInteraction, discordVoiceState: entry points that emit flow messages when Discord activity happens, from text reactions to voice join/leave notifications.
  • discord · responses – discordMessageManager, discordInteractionManager, discordTyping: nodes that send, edit, or acknowledge activity back to Discord. Use discordInteractionManager for slash-command/button/select replies; keep discordMessageManager for channel/DM messages and follow-up edits.
  • discord · guild control – discordCommandManager, discordChannelName, discordGuildManager, discordEventManager, discordPermissions, discordEmojiManager, discordRoleManager: management tooling for commands, guilds, channels, events, roles, and custom emojis.
  • discord · advanced tools – discordActivity, discordClient: status updates and advanced access to the underlying Discord.js client.
Each palette group now ships with distinct Font Awesome icons (chat bubbles for events, paper planes for responses, locks/calendars for guild administration, etc.) to make it easier to spot the node you need at a glance.
Need direct access to Discord.js? discordClient now hands you a lightweight handle (msg.discord.get() / msg.discord.drop()) instead of the raw instance so branching flows stay stable—still recommended only when the higher-level nodes can’t cover your use case.
Installation and documentation
The Wiki is still being written when it comes to documentation but you can find a guide on how to install and setup the nodes here.
Developing outside of .node-red
If you are contributing to the nodes or testing local changes, you do not have to clone the repository inside your live ~/.node-red directory. A typical workflow is:
  1. Clone this repository anywhere you prefer, for example:
    git clone https://github.com/chrobione/node-red-contrib-discord-updated.git ~/dev/node-red-contrib-discord-updated
    cd ~/dev/node-red-contrib-discord-updated
  2. Install dependencies from the project root:
    npm install
  3. To use the development version inside a Node-RED user directory, either
    • run npm install <path-to-clone> from your Node-RED user directory (for example ~/.node-red), or
    • use npm link:
      # from the cloned project root
      npm link
      # from your Node-RED user directory
      npm link node-red-contrib-discord-updated
  4. Restart Node-RED so it picks up the linked package. You can now edit code in your development directory and restart Node-RED to test changes.
Remember to remove the link (npm uninstall node-red-contrib-discord-updated) when you want to return to the published version from npm.
Publishing to the Node-RED library
Publishing a Node-RED node to the public flow library is essentially publishing an npm package, with a few extra metadata requirements. The checklist for node-red-contrib-discord-updated is:
  1. Ensure the package name in package.json starts with node-red-contrib- (in this project it is node-red-contrib-discord-updated).
  2. Verify the node-red section in package.json correctly lists all nodes, icons, and categories.
  3. Update the changelog and README to reflect the release notes.
  4. Run tests and lint checks, then build any assets required by your nodes.
  5. Authenticate with npm using an account that has publish rights to the package scope.
  6. From the project root, publish with npm publish (or npm publish --access public for the initial release).
Within an hour or so, the Node-RED flow library will automatically index the new version based on the npm publish event. For more details, see the official Node-RED publishing guide.
node-red-contrib-discord-updated gives you access to 15 nodes:
  • discordMessage is a node with no inputs and one output allowing you to receive notifications of incoming messages.
  • discordMessageManager allows (embed) messages to be sent to either channels or privatly to user. It also allows for editing and deleting of (embed) messages, including suppressing embeds or notifications.
  • discordReactionManager that allows you to listen to reactions on a message.
  • discordPermissions allows you to check the permissions of a specifc user. This is useful when you get the user from another source than the discordMessage node. discorPermissions lets you to add role to an user and to remove role.
  • discordClient is an advanced deprecated node with one input and one output allowing you to inject a references to a Discord.js Client into a message. This node can cause node-red to crash if you use it improperly, so take caution. Messages containing a Discord.js Client reference can not be forked (e.g. sent to two nodes), so you'll have to manually remove the reference to the Client via a function node using delete msg.discord.
  • discordInteraction allows you to listen to commands, buttons, select menus (string, user, role, channel, mentionable) and decide how to respond to them.
  • discordInteractionManager allows you to edit interactions by id.
  • discordChannelName allows you to change a channel's name.
  • discordMember listens when a user joins or leaves a guild.
  • discordTyping creates a 'bot is typing...' message on a channel.
  • discordEventManager allows you to create, delete, and get info events (including stage and voice scheduled events).
  • discordGuildManager allows you to get info about guilds and change name of of guilds.
  • discordCommandManager allows you to create, update and delete global application commands and guild application commands, including name/description localisations.
  • discordEmojiManager lets you create, update, list, and delete custom guild emojis.
  • discordRoleManager lists members for a role or returns a quick count with pagination support.
Changelog
See CHANGELOG.md for more info, including information regarding breaking changes per version.
Key migration points for 4.0.1
  • Palette regrouping – Nodes now appear under discord · event intake, discord · responses, discord · guild control, and discord · advanced tools. Update any screenshots or onboarding guides and look for the new names in editor search.
  • Node help refresh – Every node panel documents inputs/outputs and recommended usage. Spend a minute skimming the help for nodes you rely on if you need a refresher.
  • Node.js baseline – 4.0.1 requires Node.js 20 or newer and Node-RED 4.x, matching the new engine constraints in package.json.
  • Interaction replies – Interactions (slash commands, buttons, selects, modals) must be answered with discordInteractionManager so the interaction token stays valid. discordMessageManager remains available for regular channel messages, DMs, and follow-up edits, but should not be wired directly to interaction events.
Carryover from 3.5.x
Older migration notes still apply: the project always defers interaction replies before responding, and flows that pre-date 3.5.0 should review the interaction examples to avoid broken responses.
Examples
Privileged Intents for correct functioning
Support, issues and feature requests
For support in setting up and feature requests you can contact me on this Discord. Issues can also be reported there but prefferably via GitHub.
Discord.js client sharing
All nodes share Discord.js clients based on the discord-token that they were configured with. That means that, when you add many discordMessage nodes configured with the exact same token, only a single connection with Discord will be made.
Version: 4.1.0
Updated 1 year, 2 months ago
Rating: 5.0 2
20 in the last week
  • discord-token
  • discordMessage
  • discordMember
  • discordActivity
  • discordClient
  • discordTyping
  • discordVoiceState
  • OPENAIcodex
