node-red-contrib-discord-status 0.2.5
Change Discord custom status with Node-RED
npm install node-red-contrib-discord-status
How to install
Run this in your ~/.node-red
Introduction
With this node, you can change status in Discord with Node-RED.
Description
This node use Discord API to change your account status with node-red instead of Discord app.
  • Input: Custom status, pre-defined status <online/idle/dnd/invisible>, emoji
  • Output: Status responed from Discord
Prequisite
Login your Discord, do the capcha and accept the IP address authorization email manually
Supports:
  • Node.js v 11.15.x
  • Node-Red v 1.0.5
How to use:
  • Create flow and add this node between an inject node and a debug node.
  • Edit Discord Config node with your Discord login credentials.
  • Select required fields.
  • Inject and your Discord activity status will be changed, can check your new status in "debug" node.
Version: 0.2.5
Updated 3 years, 4 months ago
License: MOR
Rating: 1.0 1
  • discordStatus
  • token
  • discord
  • discord custom status
  • emoji
