node-red-contrib-discord-mgr 0.0.2
Allow handling of a discord
npm install node-red-contrib-discord-mgr
Node-RED Node TypeScript Starter
This is a quick-start template repository for creating new Node-RED node sets in TypeScript.
Project Structure
node-red-node-typescript-starter/
 ├──src/                             * source files of the node set
 │   ├──__tests__/                   * tests for the node set (test file names should match *.test.ts glob pattern)
 │   │   └──transform-text.test.ts   * tests for the transform-text node
 │   └──nodes/                       * node set folder, where subfolder names = node types
 │       ├──shared/                  * folder for .ts files shared across multiple nodes in the node set
 │       └──transform-text/          * source files of the transform-text node
 │           ├──icons/               * custom icons used by the node set in the editor
 │           ├──modules/             * .ts modules for the runtime side (transform-text.js file) of the node
 │           ├──shared/              * folder for .ts files shared between the runtime side (.js file) and the editor side (.html file) of the node
 │           ├──transform-text.html/ * files for compiling and bundling into the editor side (transform-text.html file) of the node
 │           │   ├──modules/         * .ts modules
 │           │   ├──editor.html      * html template for the edit dialog
 │           │   ├──help.html        * html template for the help in the info tab
 │           │   └──index.ts         * entry file
 |           └──transform-text.ts    * entry file for the runtime side (transform-text.js file) of the node
 ├──package.json                     * dependencies and node types for the Node-RED runtime to load
 ├──rollup.config.editor.json        * rollup config for building the editor side of the nodes
 ├──tsconfig.json                    * base typescript config, for the code editor
 ├──tsconfig.runtime.json            * config for creating a production build of the runtime side of the nodes
 └──tsconfig.runtime.watch.json      * config for watching and incremental building the runtime side of the nodes
Getting Started
  1. Generate a new GitHub repository by clicking the Use this template button at the top of the repository homepage, then clone your new repo. Or you might just clone this repo: git clone https://github.com/alexk111/node-red-node-typescript-starter.git and cd into it: cd node-red-node-typescript-starter.
  2. This project is designed to work with yarn. If you don't have yarn installed, you can install it with npm install -g yarn.
  3. Install dependencies: yarn install.
Adding Nodes
You can quickly scaffold a new node and add it to the node set. Use the following command to create my-new-node-type node:
yarn add-node my-new-node-type
The node generator is based on mustache templates. At the moment there are three templates available:
  • blank (used by default) - basic node for Node-RED >=1.0
  • blank-0 - node with a backward compatibility for running on Node-RED <1.0
  • config - configuration node
To generate a node using a template, specify it as the third argument:
yarn add-node my-new-node-type blank
or
yarn add-node my-new-node-config config
Adding Node Templates
If you want to make your own template available, add it to ./utils/templates/.
Developing Nodes
Build & Test in Watch mode:
yarn dev
Building Node Set
Create a production build:
yarn build
Backers 💝
[Become a backer]
Backer Backer Backer Backer Backer Backer Backer Backer Backer Backer
Testing Node Set in Node-RED
Read Node-RED docs on how to install the node set into your Node-RED runtime.
MIT © Alex Kaul
Version: 0.0.2
6 in the last week
  • discord-msg-in
  • discord-config
  • discord-msg-out
  • discord-roles
  • discord
