node-red-contrib-discord-js-drusilla 1.1.1
A node-RED module that implements Discord.js v. 12.5.3 in node-RED
npm install node-red-contrib-discord-js-drusilla
Current version: 1.1.1
This node implements Discord.js V12.5.3 in Node-RED. The only reason for it being named 'Drusilla' at the end is because i had to make the package-name unique.
Not sure where to start? Take a look at the examples!
Nodes and functionalities
  • receiveMessage
    • Receives message sent in a channel the bot has access to, or via direct messages.
  • getRole
    • Fetches the role of the user specified. Can easily be chained with other nodes in this module.
  • sendSimpleMesasge
    • Node for sending and editing messages. Supports embeds.
  • [DEPRECATED] sendAdvancedMessage
    • Ment to be a more advanced node which was only configurable using msg.properties. All of its features is now implemented in sendSimpleMessage.
Remember to get your bot-token!
Changelog
[1.1.1]
HOTFIX:
  • Logic rebuilt to properly handle setting the embed-value using both msg-properties and node configuration.
[1.1.0]
Features:
  • sendSimpleMessage now supports embeds and is now the primary node for sending and editing messages. sendAdvancedMessage is deprecated and will not receive further development or bug-fixes.
TODO:
  • getUser node
  • Sending files
  • send-nodes should have outputs.
Version: 1.1.1
Updated 5 years, 6 months ago
Rating: 1.0 1
2 in the last week
  • receiveMessage
  • DiscordConnection
  • sendSimpleMessage
  • getRole
  • sendAdvancedMessage
