node-red-contrib-dirigera-plus 1.0.0
Node-RED nodes for the IKEA DIRIGERA hub: control devices/rooms/scenes and receive live hub events (motion, buttons, open/close, state changes) via websocket.
npm install node-red-contrib-dirigera-plus
Node-RED nodes for the IKEA DIRIGERA smart-home hub.
This package lets you control devices, rooms and scenes registered on your DIRIGERA hub and — new in this package — receive live events pushed by the hub (motion detected, buttons pressed, contact sensors opened/closed, lights switched, brightness changed, …) through its websocket interface.
Lineage / credit. This is a fork of node-red-contrib-dirigera by zinen (MIT). The original control nodes are kept as-is; this package adds a new dirigera events node plus the shared websocket event infrastructure. All original functionality remains compatible.
Why this fork?
The original node can send commands and read state on request, but it does not surface the asynchronous events the hub emits on its own. Home-automation flows often need to react to the physical world — a motion sensor tripping, a remote button being pressed, a door contact opening. dirigera-plus adds a dedicated event node for exactly that, without polling.
What's new compared to the original:
  • A new dirigera events node that emits hub events in real time.
  • One shared websocket connection per hub config node, no matter how many event nodes you deploy — efficient and easy on the hub.
  • Automatic reconnect with exponential backoff (1 s, doubling up to 60 s).
  • Optional filters by event type, specific device, and device type.
From the Node-RED editor: Menu → Manage palette → Install and search for node-red-contrib-dirigera-plus.
Or from the command line in your Node-RED user directory (usually ~/.node-red):
Then restart Node-RED and reload the editor in your browser.
If you previously had node-red-contrib-dirigera installed, uninstall it first to avoid two palettes registering the same dirigera node type: npm remove node-red-contrib-dirigera.
Configuration: the hub (config node)
All nodes share a DIRIGERA hub config node. You create it once:
  1. Drag any DIRIGERA node onto a flow and open it.
  2. Next to Config, click the pencil to add a new hub.
  3. Enter the hub's IP address or hostname (find it in your router or the IKEA Home smart app).
  4. Click Get access token, then — within a few seconds — press the action button on the bottom of the DIRIGERA hub. The token is fetched and stored automatically. You only do this once.
The hub uses a self-signed TLS certificate; the nodes connect over HTTPS/WSS and accept it (standard for local DIRIGERA access).
Node: dirigera (control)
Sends commands to, or reads state from, a device / room / scene. Behaviour is unchanged from the original package.
  • Set: provide msg.topic = capability (e.g. isOn, lightLevel, colorTemperature, blindsTargetLevel) and msg.payload = the value.
  • Get: send a message without msg.topic to read the current state into msg.payload; supported capabilities are returned in msg.availableTopics.
  • Override: pick Override (msg.deviceId) / Override (msg.roomId) in the dropdown to target a device/room chosen at runtime from the message.
See examples/basic-blinds.json for a control example.
Node: dirigera events
Outputs live events pushed by the hub. It has no input and one output.
Field Meaning
Config The DIRIGERA hub config node to listen on.
Event type Only pass events of this type. Empty = all. Common values: deviceStateChanged, deviceAdded, deviceRemoved, sceneUpdated, sceneCreated, sceneDeleted.
Device Only pass events for one specific device. The dropdown is populated from the hub — deploy the config node once first, then reopen the node. Empty = all devices.
Device type Only pass events for devices of this type, e.g. motionSensor, light, outlet, openCloseSensor, controller. Empty = all types.
Filters combine with AND. Leave them all empty to receive everything.
Output message
Property Description
msg.topic The event type, e.g. deviceStateChanged.
msg.payload The event data: id, type, deviceType and the changed attributes (e.g. { isOn: true }, { isDetected: true }, { lightLevel: 40 }).
msg.event The complete raw event including id, time and source.
Example: react to a motion sensor
[ dirigera events ]  →  [ switch: payload.attributes.isDetected == true ]  →  [ turn light on ]
  1. Add a dirigera events node, select your hub, set Device type = motionSensor (or pick the specific sensor under Device).
  2. Wire it into a switch/function that inspects msg.payload.attributes.isDetected.
  3. Wire the result into a dirigera control node set to isOn on your light.
A ready-made flow is in examples/events-basic.json (event node → debug).
Node status
The event node shows its connection state in the editor:
  • 🟢 connected — websocket open, events flowing.
  • 🟡 connecting — establishing / reconnecting.
  • 🔴 disconnected — connection lost; it will retry automatically.
How the websocket connection works
  • One websocket per hub config node is shared by all event nodes bound to that hub. The connection opens when the first event node is deployed and closes when the last one is removed.
  • On any drop it reconnects automatically with exponential backoff (max 60 s).
  • The connection uses the same access token as the control nodes — no extra pairing needed.
Requirements
  • Node-RED 3.0+, Node.js 16+.
  • A local IKEA DIRIGERA hub reachable on your network.
MIT. See LICENSE. Original work © 2023 zinen; event extensions and this distribution © 2026 the node-red-contrib-dirigera-plus contributors.
Version: 1.0.0
Updated 4 months, 1 week ago
13 in the last week
  • dirigera-config
  • dirigera
  • dirigera-events
  • dirigera
  • ikea
  • events
  • websocket
  • smart-home
  • home-automation
  • tradfri
  • zinen
