node-red-contrib-digitaloak-mqtt 1.0.5
Based on core mqtt-in node, using core mqtt-broker config node. Additional features: dynamic topic subscription, unsubscribe after first msg recv option, dynamically unsubscribe specific node from specific topic, pass msgs through node.
npm install node-red-contrib-digitaloak-mqtt
MQTT input node: digitaloak-mqtt-in
Based on core Node-RED "mqtt in" node which uses "mqtt-broker" config node.
  • subscribe dynamically to topics
  • unsubscribe automatically after first msg received
  • unsubscribe dynamically specific node/nodes from topic
  • pass messages through node when msg.topic not set
Description
Subscribe to topics specyfing msg.topic
Unsubscribe node from topic automatically after first msg received, via setting checkbox in config node: "Unsubscribe from topic after first msg received"
Unsubscribe specific node from specific topic,via setting a string value in msg.payload in format "_unsubscribe:<nodeName>" ie. "_unsubscribe:waitingForResponse"
Pass msgs via node - don't set msg.topic
Usage example
Is available here: https://flows.nodered.org/flow/5492f72a81324cd3d11b51faf0304ce3
Support & Discussion
Please join: https://riot.digitaloak.it/#/room/#node-red-contrib-digitaloak-mqtt:digitaloak.it
Comments
  1. One node can be subscribed to the same topic more than once, so if you send two msgs with msg.topic set to i.e. "testTopic", then node will receive two msgs for one msg published to the topic.
It's not battle tested yet, so I will be happy for any feedback.
Version: 1.0.5
Updated 7 years, 8 months ago
29 in the last week
  • digitaloak-mqtt-in
  • mqtt
  • dynamic mqtt
  • mqtt dynamic subscribe
  • mqtt dynamic unsubscribe
